Heil Proset Headset Condenser Mic connection for ANAN 100
Posted: Sun Mar 17, 2019 5:07 pm
Hi Scott
I have a HEIL Proset headset that I think has the condenser Mic installed for ICOM. It needs Bias to work. I am not sure if the jumpers in this radio have been fiddled with but this is what I found without opening it up:
I connected the red wire from the Mic to the tip and the screen to the Sleeve. The Mic didn't work on the ANAN 100. I think the PTT jumper is connected because the radio TX,s shortly as I plug the jack into the Mic hole.
To get Bias on the mic I shorted the tip and the ring and now the Mic works. This isn't right because selecting the 20db gain selector in the setup cuts off when I select it. I think its because i have connected the tip to the PTT.
How should the jack plug be wired and what should the ANAN 100 jumper setting look like to get it to work correctly?
This is using the Mic jack input in the front of the radio.
Please bare in mind that I am not that electronic savy so a detailed explanation would be appreciated.
regards
Vince
3DA0VV
regards
Vince
3DA0VV
