Radio 1 (Anan7000dle) goes into input1 and uses the -60db tap off the amp back to BYPASS. Output1 to the antenna.
Radio 2 (HL2) goes into input2 and uses a directional coupler xtronic on the Output2 and feeds a sample back to RX3 in the HL2
Not tried as yet BUT If radio2 is used and radio1 was switched on/off could any damage take place as I presume it will still be feeding the sample into Anan7000
Many thanks in advance.
