7000 DLE and 1KW VK3AMP hook up.
Posted: Thu Oct 31, 2024 6:05 pm
by ON8EI
Hello, I recently received my VK3AMP 1KW amp plus the hook up serial cable. I have plugged it into the amp and 7OOO DLE. Please can someone who has a VK3AMP and 7000 DLE post the screenshot or shots of the settings needed.
Tnx de ON8EI John.
Re: 7000 DLE and 1KW VK3AMP hook up.
Posted: Fri Nov 01, 2024 8:23 am
by ON8EI
I'm sure I am missing something. Please help. JD.
Posted: Fri Nov 01, 2024 1:23 pm
Begging on a forum never looks good ;)
I don't have a VK3AMP, but I looked on their website and it appears they only sell parts, not entire amplifiers, and that none of the parts they sell use a serial interface. So if we are to help you then we need to understand exactly what you have there for an amplifier. Did you build it yourself from VK3 parts?
The 7000DLE does not have a serial port on it. The 9 pin connector on the back is not a serial port. If you need serial communications with any amplifier the serial port to use is one that is on the PC running Thetis, as it is Thetis that does all communications for the radio.
Posted: Fri Nov 01, 2024 1:41 pm
by PH7R
Does this help?
Posted: Fri Nov 01, 2024 3:26 pm
PH7R wrote:Does this help?
Yes, it helps.
I also found the VK3 amp manual at this link: https://drive.google.com/file/d/1EkT7ps ... N60FJ/view
Figure 1.3 in the amp manual shows the port on the amp incorrectly marked as "RS232". Again, it is not a serial port on the VK3 amp; every other part of the manual shows this as a parallel type interface with BCD inputs for band control.
Looking at the document you provided:
Do you have the cable specified?
Is it plugged into a USB port on your PC (not into the 7000)?
Do you have the correct drivers installed; is it showing up in device manager properly?
Do you have Thetis configured as shown on Page 3, especially the "Enable" checkbox?
Is the amp configured for Yaesu BCD mode?
Posted: Fri Nov 01, 2024 4:12 pm
by ON8EI
Thanks to all.
I went over it again, it seems the 9 pin plug marked amp which wasn't clear was plugged into the radio and visa versa.
All good now.
Thamks again.
BTW it's a terrific amp.
de ON8EI
Posted: Fri Nov 01, 2024 4:22 pm
by PH7R
ON8EI wrote:BTW it's a terrific amp. de ON8EI
Terrific in great or horrrible and not worth the money :lol: ? I think great, specially considering AUD/EUR exchange.
