Anan 10E PTT Out Only Working with Front Panel Mic PTT
rusham
Postby rusham » Sat Jul 03, 2021 7:23 pm
Running Anan 10E, Thetis 2.8.11, Firmware 10.3, Protocol 2, Windows10 fully updated...
I am unable to make PTT out, pin 1 of accessory connector, activate on anything other than mic PTT from front panel. PTT out will not activate using, for example, Tune, MOX, and most importantly CAT or CAT/PTT from WSJTX. The problem is that all of these inputs successfully key the rig but not PTT out, which I need for amplifier control besides mic input. I am unable to find relevant setup settings or Community topics.
If anyone could help I would be most grateful. Thanks everyone.
Russ
Re: Anan 10E PTT Out Only Working with Front Panel Mic PTT
Postby w-u-2-o » Sat Jul 03, 2021 8:07 pm
If you load Protocol 1 firmware into the ANAN does it work then?
rusham
Postby rusham » Sun Jul 04, 2021 4:21 pm
Firmware 1.5, OpenHPSDR mRX PS v3.4.8
No, TUN, MOX, CAT, CAT+PTT do not key PTT out, but front panel MIC PTT does as before.
Postby w-u-2-o » Sun Jul 04, 2021 5:32 pm
What happens when you have nothing plugged into the front panel mic connector? Does MOX etc. work then?
rusham
Postby rusham » Sun Jul 04, 2021 11:13 pm
With nothing in the front panel TUN, MOX, CAT, CAT+PTT still key the 10E but not PTT out. I also noticed today keying CW will key the 10E but not PTT out.
Postby w-u-2-o » Mon Jul 05, 2021 1:40 am
I think I've got it sorted for you: you are using the wrong pin on the accessory connector as PTT OUT. It seems like you are using the PTT IN pin, which is in parallel with the mic PTT signal. You need to use the correct pin for PTT OUT.
Take a look at the schematic here: viewtopic.php?f=35&t=2549
rusham
Postby rusham » Mon Jul 05, 2021 8:44 pm
Thanks Scott, that was the problem. Looking at the back of the 10E, I was using the bottom left-hand most "pin1" on the left side of the table AND the red pin number assignments in the User Guide. Reading table numbers on the right side indicated "pin 25" which per the red numbering is the bottom right-hand most pin which works fine. MOST confusing but all's well that ends well. I can't thank you enough for your help.
73, Russ, K3RH
