Two Thetis 2.9.0 CAT-related questions
W9IP
Postby W9IP » Thu May 05, 2022 12:13 pm
Dear friends,
1) Is there a summary of the new CAT commands?
2) Is it possible to read the current noise floor value via CAT?
W9IP
Re: Two Thetis 2.9.0 CAT-related questions
Postby w-u-2-o » Thu May 05, 2022 12:24 pm
The answer to your question is in the very first post, a tacked topic, right here:
viewforum.php?f=16
And it's "sort of, not fully up to date" and "no".
I have started compiling an up to date CAT document, but it's slow going, and I have many other projects active at the same time.
I'll be moving this topic to the rig control sub-forum...
W9IP
Postby W9IP » Thu May 05, 2022 12:32 pm
Yes, I read that topic prior to posting my question. In my question, "new" = ver 2.9 to which I see no reference. I'll dig into the source code for now.
W9IP
Postby w-u-2-o » Thu May 05, 2022 12:40 pm
It doesn't appear you read that topic closely enough.
There is no need to dig into the source code. Just look at the catstructs.xml file, just as it says in the above referenced topic.
