Release: Twigger
Release: Twigger
Postby oe3ide » Tue Sep 03, 2024 6:08 pm
I wrote a new software ;-) Its called Twigger. In a nutshell: A very lightweight QSO-Logger with TCI-Connection and Mini-View.
https://www.oe3ide.com/twigger/
73 de Ernst, OE3IDE
KC2QMA
Re: Release: Twigger
Postby KC2QMA » Tue Sep 03, 2024 11:40 pm
Thank you again!
I have Thetis TCI default setting how do I set up twigger with Thetis TCI?
Postby oe3ide » Wed Sep 04, 2024 4:48 pm
KC2QMA wrote:Thank you again!
Usually 127.0.0.1 Port 50001
Postby oe3ide » Tue Sep 10, 2024 10:05 am
Released version 1.1.5:
New since initial release:
added: new field comment
added: option to show comment-field in mini-view (settings)
added: setting to change output folder for adifs
added: option to send spot or delete spot from grid view (right click)
added: Export to ADIF with date from/to
added: right-click on qso-row => send telnet or delete qso
added: qso counter
added: OmniRig support
added: telnet dx-cluster support
added: send spot to telnet dx-cluster
added: click on time in mini-view starts/stops the qso auto timer
added: dupe search band/day based
added: save qso on ENTER in RST_sent/RST_rec/Name/QTH
added: highlight mini-view when activated and already visible (yellow form border)
added: RST r/s also in mini-view
changed: closing main windows only closes application if mini-view is not shown and vice-versa
changed: flipped RST R / RST S order on main and mini
changed: mini-view resizable
changed: Twigger comes now with an installer (default dir is c:\users\<your usser>\documents\Twigger … you can change it on install)
changed: reconnect timer to non ui-blocking async task
changed: auto capital in callsign fields
changed: font in call-sign fields now AnonymousPro Bold
changed: callsign length on save min 3 chars
changed: qrz.com query with timer
changed: all fields are now synch’d between main and mini
changed: qrz.com query is now cached, to avoid multiple queries for same callsign
fixed: qth was filled with , when no qrz-data available
fixed: correct default size of mini view – fix on restore position
fixed: qso-time now UTC
fixed: vertical line on columns resize
fixed: application closing when debug-console is closing
removed: output to Twigger_ALL.adi
73 de Ernst
OE3IDE
Postby oe3ide » Fri Oct 18, 2024 5:50 pm
New version 1.1.15 is released:
New since 1.1.5:
    fixed: position spot form
    fixed: resizing code
    added: template for spotting text (see settings)
    added: rotator (PSTRotator) support
    added: saving of ANT_AZ into ADIF
    changed: comment field now resizes with the window
    fixed: updater was not brought to foreground, when main was minimized
    added: up/down and mouse-scroll to change RST values
    added: callsign info to mini-view
    added: click on spot in Thetis puts it into callsign field
73 de Ernst, OE3IDE
