TCI and JTDX
Posted: Wed Mar 09, 2022 4:42 pm
by Tony EI7BMB
Is anyone seeing any issues using TCI with JTDX software? JTDX crashes on frequency or band change occasionally. I have tried changing TCI server to 40001 without success. Reverting back so standard CAT seems to cure the problem. I'd welcome any thoughts on this.
Re: TCI and JTDX
Posted: Wed Mar 09, 2022 11:23 pm
by w9mdb
What version of JTDX and what version of Thetis?
Some TCI timing was fixed in JTDX 2.1.159
Re: TCI and JTDX
Posted: Thu Mar 10, 2022 9:33 am
by Tony EI7BMB
JTDX is 2.2.159 and Thetis is 21k9rc4b
Re: TCI and JTDX
Posted: Sun Mar 13, 2022 1:38 pm
by vk6cpu
HI Tony
runing two instances of JTDX here on RX1 & 2 using TCI
It appears to be behaving itself. Only issue I have noted is that occasionally/randomly PWR output slider in JTDX resets to 0.
Otherwise all good so far.
Re: TCI and JTDX
Posted: Sun Mar 13, 2022 1:44 pm
by Tony EI7BMB
Edit: Took a lot longer this time but JTDX has crashed again. I'll keep investigating to see if I can narrow down the issue.
"Hi Nigel, I'm trying it again today with latest release of Thetis 21k9rc5. Fingers crossed its ok so far"
Re: TCI and JTDX
Posted: Mon Mar 14, 2022 11:49 pm
by vk6cpu
RC5b works well. Nothing noted untoward. Appears stable/
The random return of the power slider to 0 is not a TCI issue - noted it happening on another instance - Icom 9700.
One unexpected "feature" I have noted with TCI, if RX2 is off and I start the 2nd instance of JTDX which references RX2 it turns RX2 on. Even tho the power on/off option isn't selected on the Radio Tab.
AS yet TCI on Anan/Thetis doesn't appear to support display of signal strength/power out via JTDX.
Re: TCI and JTDX
Posted: Tue Mar 15, 2022 1:09 am
vk6cpu wrote:RC5b works well. Nothing noted untoward. Appears stable/
yes, if external program sends message rx_enable:1:true; (the 1 signifies rx2) then RX2 will be shown in thetis, irrespective of power state. RX1 is there, why cant RX2 be there as well?
yes, signal str/power out etc (sensors) are not implemented
