Starting from Scratch Again with Digital Setup
Posted: Sun Mar 13, 2022 8:22 pm
by AB5N
Hey guys. Well, set the Laptop up for another radio on FLdigi and WSJTX and I'm starting from scratch again with setting up 7000 DLE/Thetis.
Virtual audio cables work and Com0Com used to work. I can't get any communications between the PC and Laptop. Even a DTR/RTS separate port PTT isn't working anymore. CAT comms may well be dead in my 7000/Thetis setup. Since there is no one resource on getting digi going, anyone have a pointer where I might find info? Standard Digi setup from Thetis manual does not work for me. Any ideas if CAT communications doesn't work at all? Thanks- Bob
Re: Starting from Scratch Again with Digital Setup
Posted: Sun Mar 13, 2022 8:32 pm
AB5N wrote:I can't get any communications between the PC and Laptop.
Are you saying that Fldigi and WSJT-x are running on a laptop, and Thetis is running on a separate PC?
There are no problems with CAT comm's in Thetis, or Fldigi, or any other software. All is as it should be. It's just you need help soldering together your software ;)
