"Conflict" between TCI and TCP?
Posted: Fri Mar 29, 2024 4:20 pm
I did have my N1MM+ logging work pretty well about a year ago. Will retrace the steps I took to see what the mistake is that I will have committed. From memory, I think that I operated my SS amp using either RF sensing or CAT control, NOT TCI, which may explain why I got it all to work.
The amp, Thetis and N1MM+ are all on the same PC. Unmanaged Ethernet T switch used to tie pieces of hardware together.
Played around with this yesterday and for some reason:
1). The frequency on the N1MM+ spectrum did not match that on the Panadapter of Thetis. The N1MM+ frequency was always off, but it did change when I tuned to another frequency on Thetis, remaining off compared to the frequency displayed on Thetis.
2). The number of TCI clients kept rising from the normal 1 (I use TCI with my RF2K-S amplifier and it works very well). However, I also have a USB connection between the amp and Thetis. TCI is for use of VNC (Virtual Network Control) that enables porting the amp GUI and operating the amp via a mouse on the external display.
Realizing that I haven't included screen-shots, I will do that a little later, not to waste anyone's time (which I may have already done
Happy Easter/Holiday!
