Band decoder tor Anan
Postby oe3ide » Sat Jul 03, 2021 1:24 pm
Just finished my last little project. I have a remote antenna switch from EA4TX. The controller is accepting band data in Yaesu and Icom format.
The universal band decoder converts the regular Kenwood cat-data into BCD or Icom Voltage band data. So the RS232 is connected to the PC (COM5). In Thetis I have activated this com port.
The decoder polls every 500ms (sending "IF;") and sends the band data to the EA4TX-Controller. Amp-key-in is for protecting against hot-switching.
OE3IDE
EA1DAV
Re: Band decoder tor Anan
Postby EA1DAV » Sun Jul 04, 2021 8:52 am
Hi Ernst, I do the same with the Open Colector out in the back of my 100D and the 6x2 EA4TX box. Pull up resistor needed.
73, ea1dav
Postby oe3ide » Sun Jul 04, 2021 9:15 am
Yes, I also considered using OC. But I wanted to be independent of the Anan hardware, which is why I chose the Cat interface.
K4IBC
Postby K4IBC » Mon Oct 31, 2022 11:25 pm
Hello Ernst,
I was searching for a hardware solution to interfacing to my Icom PW-1 and came across this interface.
It appears it would take Kenwood serial data and convert it to Icom CIV data. Is this true?
I found the guys website and eBay listing but unfortunately he doesn't sell to the U.S.
Postby oe3ide » Tue Nov 01, 2022 7:59 am
exact. It takes Kenwood protocol and puts out Icom Band voltage or BCD (Yaesu).
K4IBC
Postby K4IBC » Tue Nov 01, 2022 1:46 pm
Thanks Ernst,
I was able to get in touch with Anton and ordered a couple of converters. Trying to make this as automatic as possible for the PW1. I am getting old and forgetful. I know I could have done it thru additional software or manually but that left too many points of failure.
K4IBC
Postby K4IBC » Sun Dec 25, 2022 6:45 pm
Got a nice Christmas gift in the mail yesterday. The converters arrived here in the states in just about 8 weeks. Not too bad considering.
I do have a question about a couple of things I am noticing on the board. There in a 4 pin solder pad near the cpu. No documentation I can find mentions it and not on the schematic. Also near the USB connector is two areas which look like solder jumper pads. Any clue what they are for?
The with/without Mode Logger jumper. Is it simply a means to disable date on the USB jack?
Unfortunately I didn't realize he used a mini USB connector and I don't have a cable to fit. I will have to wait to test it.
IMG_20221224_164134985 (3).jpg (4.41 MiB) Viewed 8123 times
