The Anan 10E manual I have says in Chapter 2 : Connect a suitable ground cable to the rear panel ground terminal and to a suitable RF ground, in
accordance with good amateur practices.
Was a ground lug present on the A-10, but not the A-10E, by chance? I'm just not seeing how I am supposed to do that.
Also, I read online that my 200D and 10E both exhibit a Pin1 problem, with respect to chassis grounding of the audio. I was curious if anyone has 'fixed' either of those, mostly how you did it.
Greg, K3RW/KH7
