Anan-10 Disassembly
WB4AIO Kevin
Anan-10 Disassembly
Postby WB4AIO Kevin » Wed Mar 28, 2018 5:43 am
Hi all:
Where would I find instructions for disassembling the Anan-10?
Kevin.
Better fidelity means better communications.
Re: Anan-10 Disassembly
Postby w-u-2-o » Wed Mar 28, 2018 12:06 pm
Hi Kevin,
I hope someone else answers because I've never taken apart a -10. However it would appear similar to the -100 and -200 radios I'm familiar with, so I took an educated guess below that perhaps may be helpful.
1. Remove screws from front panel.
2. Remove front panel and detach power button or power button wiring from front panel. Lay front panel aside.
3. Remove nuts and washers from BNC connectors on rear panel (be gentle with these when you put them back on, a lot of torque is not necessary).
4. Remove screws from rear panel and pull away from the main chassis.
5. Carefully label the coaxial cables.
6. Remove the hardware from the SMA connectors and separate the rear panel from the radio.
7. I believe at this point you can slide the Hermes and PA/RF board from the housing as a unit--not sure because this is definitely different than the 100 and 200 I'm familiar with.
8. Carefully mark the orientation of the IDC connector connecting the two boards.
9. Further disassembly as required/desired.
WB4AIO Kevin
Postby WB4AIO Kevin » Wed Mar 28, 2018 2:50 pm
Thank you, Scott. Will give it a (careful) try this week.
Kevin.
