Anan7000 DLE, HW defekt, no ampere display on Thetis
Posted: Fri Jan 22, 2021 7:38 am
by DG1LT
Hi there,
when repairing my Anan700DLE, I had a defective U17 (ADC78H90CIMT) on the Orion board. During assembly, I plugged the Orion ribbon cable into the wrong connector on the PA board. J17 is correct, I stuck to J22.
The V (volt) indicator and the FWD_PWR and REV_PWR are fine with the new ADC78H90CIMT.
But the ampere display on Thetis 2.8.11 doesn't show me anything, what could be the problem?
Thoren
Re: Anan7000 DLE, HW defekt, no ampere display on Thetis
Posted: Thu Mar 18, 2021 5:17 pm
by DL8LAQ
Hi Thoren,
did you solve your problem?
Posted: Fri Jul 09, 2021 4:02 am
by DG1LT
Hello Norbert,
unfortunately not, I can't find the place where the current is measured (ampere).
It must be on the PA board. The Thetis always shows 0.0 amperes.
73 Thoren[img]
[/img]
Posted: Fri Jul 09, 2021 10:02 am
by DL8LAQ
DG1LT wrote:unfortunately not, I can't find the place where the current is measured (ampere).
[img]Ampere.png[/img]
Hi Thoren,
U12 on the pa board is the current sensor. On J22-1 you can probe the signal coming from the sensor. You should see a voltage proportional to the current draw of the pa. The ACS713 datasheet might be helpful. U1008A (LM358) is an impedance converter / driver for the current signal.
PA board J22 goes to J10-1 on the spreadout pcb, further to J2-11 and via the ribbon cable to the Orion board J16-11 through filter FL8 to U17-7.
If I disassemble the 7000 the case with the pa board stands upright (perpenticular) and the bottom plate with the Orion is placed flat on the bench. So I can run the unit with all cables connected.
Posted: Wed Jul 14, 2021 10:24 am
by DG1LT
Hello Norbert,
at the weekend I will disassemble the device, thank you very much for your information.
73 Thoren
Posted: Wed Jul 14, 2021 10:42 am
by DG1LT
I'm curious what is broken. I inserted the 10 pin cable incorrectly.
J15 Orion on J22 PA
J10 Ext. To J7 PA
That was wrong, the U17 (ADC78H90CIMT) on the Orion Board is already new.
What is still broken now?
Posted: Wed Jul 14, 2021 12:53 pm
by DL8LAQ
DG1LT wrote:I'm curious what is broken. I inserted the 10 pin cable incorrectly.
J15 Orion on J22 PA
J10 Ext. To J7 PA
My crystall ball is broken
I have disassembled and reassembled many ANANs but never failed to plug the ribbon cables into the wrong place. Every time I disassemble a unit I take a bunch of photos.
You should key / unkey the tx and use an oscope to follow the signal to the place where it disappears.
Posted: Thu Jul 15, 2021 4:49 pm
by DG1LT
Hello Norbert,
the ACS713 is defective. Pin 7 is 0.35V in RX operation and 0.62V in 45W TX. If I apply 5V to R91, the Thetis will display 53A.
If the ACS713 is a 20A or 30A version, I can only see ACS713T. Do you know a fast source of supply with cheap shipping. Thank you in advance for your good help.
73 Thoren
Posted: Fri Jul 16, 2021 6:58 am
by DG1LT
the 30 amp type is installed...
Posted: Fri Jul 16, 2021 4:00 pm
by DL8LAQ
DG1LT wrote:Hello Norbert,
Digikey has this device in stock. A quick search for other sources in DL failed.
Posted: Fri Aug 20, 2021 5:59 am
by DG1LT
Hello Norbert,
I finally got the current sensor and installed it. What I notice is that the Anan only shows 0.1 A at 13.6 V in RX mode. With TX FM, 12.7 V voltage dip with 95W approx. 12.5 A. If these values are OK, I suspected that the sensor delivers more precise values.
73 Thoren
Posted: Fri Aug 20, 2021 5:38 pm
by DL8LAQ
73 Thoren
Moin Thoren,
my 7k shows 13.7 V / 0.0 A in rx mode and 13 V / 17 A during a 100 W tune on 10 m. SWR is 1.6. I'm fine with this readings.
Posted: Sun Aug 29, 2021 7:05 am
by DG1LT
Hello Norbert,
then everything is as it should be, device has been successfully repaired. Thank you again for your assistance with troubleshooting.
I still have some current sensors here in case anyone needs it.
73 Thoren
