ANAN 100B BURNT TOROID L9 ON PA FILTER BOARD
Posted: Sat Apr 17, 2021 1:15 pm
by VE2SCA
Hi and thanks for reading this.
As the subject says, the L9 toroid is in a pretty bad shape and need replacement. The inductors in this portion of the PCB where too close to each other. So, the result is a loss of power on 20 meters and a electronic burnt smell when it happened but it runs a few years before the problem occurred.
Please, can someone tell me where the heck I can get one or two of this 311 nH toroid?
Tried on Digikey and others but for no go.
Maybe is it better to ask Doug W5WC for this?
Thanks Scott - WU2O and others for the ANAN forum and have a great day.
73 de Stephane VE2SCA!
Re: ANAN 100B BURNT TOROID L9 ON PA FILTER BOARD
Posted: Sat Apr 17, 2021 2:05 pm
Contacting Doug or Apache is probably your best bet.
Or perhaps someone like Kjell @LA2NI might be able to tell you how to wind a new one from scratch.
Posted: Sat Apr 17, 2021 4:16 pm
by VE2SCA
Ok thank you Scott, I emailed them my request.
Have a nice day and an Happy World Amateur Radio Day 2021 on Sunday, April 18 by the way.
Posted: Sun Apr 18, 2021 4:38 am
by dj1yr
is an Amidon T50-6 with 9 turns 0,6 or 0,8mm Cul.
Sweep all filters please, especially the filters from 30m are critical.
Then check if the correct filter was switched, there were firmware versions that did not select the correct filter, you can see the result.
The next thing is, the LPF is not built for 100W, 100% duration, max 50W continuous.
Posted: Sun Apr 18, 2021 1:58 pm
by VE2SCA
Hi René DJ1YR and everybody.
Thank you for the reply, I managed to get the core online, and the wire here locally.
Special thanks to Doug W5WC that gave me the table of all the core in the radio.
Here's the table FYI:
QTY REF.DES. TOROID TURN WIRE LENGTH
1 L3 T68-2 25 TURN 47.3 CM
1 L4 T68-2 28 TURN 50 CM
1 L5 T50-2 18 TURN 33 CM
1 L6 T50-2 20 TURN 36.8 CM
1 L7 T50-2 15 TURN 28.3 CM
1 L8 T50-2 16 TURN 30 CM
3 L9,L14,L21 T50-6 9 TURN 17.5 CM
1 L10 T50-6 12 TURN 22.5 CM
1 L13 T50-6 8 TURN 17 CM
1 L15 T50-6 6 TURN 13.9 CM
1 L16 T50-6 7 TURN 16.2 CM
1 L17 T50-10 8 TURN 17 CM
2 L18,L22 T50-10 7 TURN 16.2 CM
2 T4,T5 FT50-43 20 TURN 36.8 CM
1 T3 FT37-43 12 TURN 19.6 CM
1 L23 FT50-43 10 TURN 21 CM
Thanks again and have a nice day.
Posted: Sun Jun 20, 2021 8:45 pm
by VE2SCA
Hi dear OM's of Apache Labs forum.
FYI, I replaced Toroid #L9 because it was totally burnt. Radio got back is 100 watts but just for a few minutes, after FT8 key down that I used to do since 2 years, now it is burning right away. (maybe I was lucky but is was too much power handling and duty cycle)
I checked everything, put back a new toroid at L9, and this time, I did not let it burn right away, but I have another problem in that area of the PA board.
So for now on, I am suspecting a bad G6A-274P (K10) and or some caps in the vicinity of the circuit. (will get a good cap multimeter)
I can have DS2E-ML2-DC12V Relay Latching PCB DPDT 12V 2A in Montreal, just near by.
SWR bridge seems OK. Power on the other bands ok, only 17 meters experiment the same issue since it is the same circuit.
I'll will get back later with this when I'll complete this fix. (hoping so)
Please, if you have more informations on this issue, fell free to reply. It is not seems to be a common issue since I do not find anything on this trouble.
Good luck and 73's to all.
Stephane VE2SCA
L9 circuit area
Posted: Sun Jun 27, 2021 12:39 pm
by VE2SCA
Got some similitude issue in this topic:
https://apache-labs.com/community/viewtopic.php?f=17&t=2939
