Thermistors in the ANAN-8000DLE AMP board
Posted: Sun May 23, 2021 7:00 pm
As you know I was struggling with heating up the amplifier to 40-42 quite soon and then receiver sensitivity used to go down.
Later I realised that they are different issues. Sensitivity was going down because of the J3-J3 cable between the Antenna selection board and the control board.
The problem disappeared after taking out the cable and inserting again for some time and came back again but the problem is there because of the cable and also probably because of a relay.
Once sensitivity goes down, It comes back after some time and the radio needs to shut down for an hour or more. If it does not comes back even then, and I press tune momentarily and the radio gets life again for some time. In your opinion this pressing tune business relating to the relay?
Today I was looking for something in various reviews of this radio and found one such review by Mark Abraham NI0Z of sdrzone (https://sdrzone.com/index.php/en/56-ana ... dle-review) and noticed the picture of amplifier board and noticed R22 & R32 are touching the heatsink compound to probably sense the temp of the heat sink and both the legs are insulated while in my board these are in the air above the slot on the PCB. Attached, please find both pictures. Please let me know if it would be beneficial in any way if I insulate the legs and put the heatsink compound in the slot and let the sensor touch it?
Thank you for your support
Bhanu
VU2MB
Bhanu
VU2MB
