RX2 Isolation and Internal Noise Question
Posted: Wed Jan 05, 2022 2:03 am
RX2 Isolation Question:
I noticed this radio does NOT have much isolation from ANT1 AND RX2 antenna ports.
I have physical switches on both my Main Antenna and my Receive Only Antenna, both plugged into the appropriate ports on the radio.
When I switch OFF my main antenna and have my receive antenna on, the MAIN receiver window picks up about 20 db noise compared to if I then switch OFF my RX antenna.
Is this normal for this radio? Comparing it to my FTDX101 - there is complete isolation.
Internal Noise?
Note the pictures. I could not take a screen shot as I had everything unplugged except the bare minimum to run the anan. I have ruled OUT power supply and ran on battery - and the picture is with both antennas unplugged.
Is this normal?
Internal Noise?
Is this normal?
