Palstar LA-1K Pure Signal Jack
Posted: Thu May 06, 2021 1:35 pm
by NI0Z
I recently just received my Palstar LA-1K and noticed it has a Pure Signal Jack on back, anyone using it and how would it connect to the Anan 7000 MKII Black?
- PureSignal Amp.png (2.01 MiB) Viewed 14341 times
Re: Palstar LA-1K Pure Signal Jack
Posted: Thu May 06, 2021 2:41 pm
If it were me I'd just run a cable between that jack and the Rx Bypass jack on the Anan.
It'd need to be a custom cable, with a BNC connector on one end and an RCA plug on the other end.
But that's just me..
EDIT: Here's a review by
W1TR@arrl.net on that amp, it mentions the PureSignal feature:
https://static.dxengineering.com/global ... -1k_zz.pdf
Posted: Thu May 06, 2021 4:17 pm
Mark is correct, of course.
You need to set the "Bypass on TX" option in the settings so that the radio uses the external feedback signal instead of one from the internal coupler.
Posted: Mon May 10, 2021 2:15 am
by NI0Z
Ok, got that, but will it also correct the Amps output as well as the Anans? I am guessing no, of course PureSignal still gives a cleaner signal to the am to work with. That being said I am guessing with the newer Anans it's not needed?
Posted: Mon May 10, 2021 11:44 am
NI0Z wrote:Ok, got that, but will it also correct the Amps output as well as the Anans?
Yes, that's the entire point of using a feedback signal coupled off of the amp output. PureSignal will make the necessary corrections in order to achieve linearity at the point where the feedback signal is coupled from, in this case the output of the external amplifier.
Think about it mathematically: PS knows the shape of the input signal. PS is measuring the output, in this case at the output of the external amp. It does the math to make the output look like the input.
That's definitely not true. Without PureSignal the linearity of all ANAN models, newer ones included, is not significantly different or better than any other amateur radio transceiver. And, as a group, non-linearized amateur radio transmitter linearity is pretty poor, with IMD products in the -30 to -40dBc range. That's why PureSignal is so awesome. It can take that mess and reduce IMD products down to about -60dBc.
Posted: Tue May 11, 2021 5:48 pm
by NI0Z
Posted: Tue Jun 15, 2021 12:32 pm
by 46flatlander
K1LSB wrote:If it were me I'd just run a cable between that jack and the Rx Bypass jack on the Anan.
Can I assume the cable mentioned is the only hardware needed to connect my 8000 to
my LA-1K ? Thank you
Posted: Tue Jun 15, 2021 1:37 pm
You mean besides a main RF cable and PTT cable? Yes.
Posted: Tue Jun 15, 2021 7:28 pm
by 46flatlander
Thanks Scott!
Posted: Wed Jun 16, 2021 1:11 pm
by 46flatlander
Which terminal on rear of 8000 corresponds to the" RX Bypass Output" mentioned on earlier Anans (PS Input) ?
Trying to connect to Palstar LA-1K Pure Signal input. Thank You
Posted: Wed Jun 16, 2021 2:25 pm
On the 8000 you remove the coax jumper on the PS connectors and apply the external coupler signal to the PS Input connector.
Posted: Wed Jun 16, 2021 6:44 pm
by 46flatlander
Scott, Once again I thank you !
Posted: Tue Jun 22, 2021 11:03 pm
by 46flatlander
Here's my 1st attempt running 500 watts cable from Palstar amp to 8000.
Any comments would be helpful. Thanks
Posted: Wed Jun 23, 2021 2:18 am
The data shown on the AmpView display looks not so good. Linear, but those lines should be filled in more, and the blue line should not make a "loop". What does it look like with the Low Res box unchecked, what does the DUP display look like, i.e. what kind of IMD products are you getting?
Posted: Wed Jun 23, 2021 8:40 pm
by 46flatlander
Do I need to terminate open terminal "Feed Back Input" on the rear of my 8000 ?
Posted: Sun Apr 24, 2022 8:19 pm
by 46flatlander
You need to set the "Bypass on TX" option in the settings ? Where in the settings ? Thank you
Posted: Sun Apr 24, 2022 9:21 pm
Setup > General > Ant/Filters > Antenna. This is for all models with a Bypass input (not the -10 series, not the 8000).
Since you have an 8000 you will not find this option available for your radio, so no need to look
Posted: Sun Apr 24, 2022 10:05 pm
by 46flatlander
Thanks for that Scptt,now I know why I couldn't find it !
