Pure Signal 2.0 GetPk and SetPk values
Posted: Tue Mar 15, 2022 2:29 pm
My only observation about these two items is that the GetPk value changes slightly as Pure Signal goes about the business of correcting non-linearity in the PA of the ANAN (internal coupler being used) or in an external amplifier (external coupler feeding a sample to the bypass port). When transmitting SSB, as you speak the GetPk value will rise and fall apparently in response to the quality of the RF output signal that is produced. I have no idea what that number means or what it does but I assume it's an indication of the Pure Signal algorithm at work.
The bigger mystery to me is the value of the SetPk setting. When I questioned a few ANAN users on the air who were using a mix of Orion II and Orion boards it looks like 0.2899 might be universally applied. However, I'm not sure what SetPk value is used with the Hermes, Hermes 14-bit, and Angelia boards so that might not be correct. In any event, I wonder if anyone can answer these questions:
1. Is this number used across all models of the ANAN radios?
2. If so, why is that number used?
3. What happens if a user increases that number?
4. What happens if a user decreases that number?
5. Is the SetPk number something that could be adjusted by an end user who is having issues with stable correction?
I admit that I experimented with increasing and decreasing the hundredths digit of the default SetPk value by 1 or 2 but could not conclusively see much difference in the behavior of Pure Signal. I didn't "play" further because I really don't know what the SetPk value does and although I like to tinker I don't want to unintentionally invite disaster!
Does anyone on the forum have information about the SetPk setting?
Thanks, Rob W1AEX
Thanks, Rob W1AEX
