Is There a Thetis Diversity Basics Tutorial?
Posted: Mon Mar 31, 2025 6:14 pm
The Thetis manual is quite brief in its description and instructions, I'm wondering if there's a better tutorial available? I'm not getting much (or anything) in the way of noise reduction or signal improvement. I've got a mag loop for RX1 and using an active whip on RX2. Sync is on and I've tried both antennas as reference source.
Further questions:
- What are the proper settings under General>ADC? Do the defaults settings work?
- Should AGC be set manually for both receivers? At what level?
- Should ATT be set for either receiver? I saw one YouTube tutorial that stated that was necessary. Unclear why.
- Will I only see results for specific types of local QRM? Maybe I'm hoping for too much?
Further questions:
