1. Imported the Database that I had been using successfully (radio talking to PC via the Ethernet switch).
2. Reconfigured the NIC to use DHCP instead of the static IP address I had assigned it.
In Windows (networking), I checked the 2 boxes below:
Obtain an IP address automatically
Obtain DNS Server address automatically
No joy, I get a pop-up suggesting that the radio isn't powered on or is not connected.
The above problem is likely, once again, a shortcoming in my understanding networking principles, but I am hoping to be able to get up to speed eventually
UPDATE:
When reverting to automatic IP, I hadn't written anything in the IP field using the Bootloader. Works fine now.
