Protocol 2 Problem on My Network
Posted: Thu Oct 15, 2020 3:28 pm
Hello to all. I just acquired a 7000DLE and have a problem that some Protocol 2 guru will understand, so here goes.
It appears that I have a Protocol 2 problem and I have the problem identified. I just don't know why. I have a workaround but it's not a fix. My network configuration is not prohibitively complex but it is not simple either.
I am using a 7000DLE and a NUC 8i5 with Windows 10. This new release of Thetis, now 2.8.9 is probably the reason I've been able to identify the problem. The concept of allowing it to run with P1 or P2 was genius!
With P1, I've never had any problem at all. openHPSDR 3.4.9 has run great for a couple of years. Monday I loaded the new Thetis 2.8.8. It ran perfect also on P1. So then I decided to go to P2. It refused to run with P2 loaded. This has been tested with a 200D and my 7000DLE with the exact same response.
When starting Thetis on P2, the main form would appear and when I clicked the start icon, it would illuminate for a couple of seconds and then Thetis would shut down.
I connected the NUC directly to the 7000 and Thetis ran perfectly. When I connected them back into the network, it would fail again. I began removing devices from the network and identified 3 devices, any one of which would cause the failure. 2 were Raspberry Pi 4B's and the other was a Firewalla Blue. The thing they have in common is that they are ARM processors and each runs on a modified version of the Linux Debian OS.
Going back to the NUC, if you power it completely down and back up, Thetis will fail every time. If you check the ARP Table the radio does not appear, however the correct firmware information shows up on the setup screen in Thetis. That tells me that the NUC/Thetis and the radio have communicated. Now, if you manually enter the radio in the ARP Table or remove all 3 ARM devices, it runs like a champ, no failure.
It also runs fine, full network, with Protocol 1. No issues.
I am stumped!
BTW Thetis 2.8.9 is FANTASTIC! 73 -- Larry W9MDX
I am stumped!
