7000DLE MKII Black - IP Dissapears After A Few Seconds
Posted: Sat Feb 27, 2021 4:03 pm
by mcindan
I have a brand new 7000DLE MKII (Black Edition) just out of the box. When I connect it to my router I see an IP assigned as expected but then it disappears after a few seconds.
The radio in NOT in bootloader mode. When I put it in bootloader mode and power on, NO IP is assigned.
Any Ideas on where to start?
Re: 7000DLE MKII Black - IP Dissapears After A Few Seconds
Posted: Sat Feb 27, 2021 4:48 pm
by mcindan
I could not get DHCP to work so I set the IP using the bootloader and installed protocol 2 v2.0.b firmware while I was at it.
Once the radio was rebooted (non bootloader mode) I could ping the IP I set above and Thetis v2.8.11 is now working.
Any ideas on what might be going on with DHCP, where the IP is set then it disappears?
Posted: Sat Feb 27, 2021 5:14 pm
What do you mean by "disappears"? What tool are you using to check the IP? If it is ping, you should know that neither Protocol 1 or Protocol 2 provides reliable ping responses. Chances are it was/is working just fine with DHCP, just not with ping.
Posted: Sat Feb 27, 2021 5:58 pm
by mcindan
I am looking at the router (RT-AC68U) list of clients. For some reason the IP appeared in the list when the radio is first powered on but then disappears from the list after a few seconds. No issues with ping since I set the IP address via the bootloader.
I will use a static IP going forward - I was just wondering if anyone else had experienced an issue like this.
Posted: Sat Feb 27, 2021 7:55 pm
For the record, DHCP works perfectly here on an 8000 (same board as the 7000) under both P1 and P2 firmware.
Posted: Sat Feb 27, 2021 8:39 pm
by mcindan
w-u-2-o wrote:For the record, DHCP works perfectly here on an 8000 (same board as the 7000) under both P1 and P2 firmware.
Thanks! I suspect it is an issue with the router. Since all is working via the static IP I will leave it for another day.
Posted: Mon Apr 19, 2021 9:36 am
by I2NOY
I have experience that some DHCP server of routers is not 100% compatible with some devices.
Keeping a fixed IP would not hurt, on the paper.
I am still waiting my 7000 DLE MK2 black and when it will arrive I will check with my Fritz touter.
Posted: Wed May 05, 2021 12:16 pm
by FM5GB
Hi all
I have (had) exacly the same behaviour on my router (RT-AC66U, same as your's but without modem) : it would show the radio as long it has power supply but when power on is activated it would disappear after some time (for the router to routine scan the network). I don't think this impairs any functionnality. Now I'm using a separate NIC to connect the radio to the computer and by the way this improved only marginally the problem of audio & video dropouts at maximum sample rate in FM with my transverter.
73s Phil FM5GB
