Flashing ANAN 200 D with New Protocol
Posted: Sun Jul 16, 2017 8:25 pm
by ON8GE
This morning, I tried to upgrade my 200D with the 1.1 firmware but it seems not working.
It is not detected anymore on the network. Is it a special process to upgrade the device ?
Best 73's and long life to Apache Labs
Pierre
ON8GE
Re: Flashing ANAN 200 D with New Protocol
Posted: Sun Jul 16, 2017 11:23 pm
Do you have a gigabit Ethernet connection to the radio?
Are you running Thetis as your SDR software?
Posted: Mon Jul 17, 2017 7:32 pm
by ON8GE
For both questions, the answer is yes
Posted: Fri Oct 05, 2018 9:24 am
by A92GE
I wondered if you made any progress? I tried many times (using various releases) to install the Protocol 2 firmware. It has loaded successfully but never worked. I also have a direct Ethernet connection to computer with high quality CAT6 cable. The only notes I can find all assume that it is an error with loading the firmware but I have enough technical knowledge to know that for me that is not the issue. It appears not to initialise the Ethernet port.
David
A92GE
Posted: Fri Oct 05, 2018 11:34 am
The most common problems are:
a) not downloading the file correctly
https://apache-labs.com/community/viewtopic.php?f=18&t=2376
b) P2 firmware is not even beta yet, so it simply might not run on your particular serial number radio.
Posted: Sat Oct 06, 2018 7:14 am
by A92GE
Thanks. I guess I am unlucky. The rbf files that I am installing are the correct size (1856Kb for v1.1) and take about the same time to upload as the version 1 protocol. So I am going with your (b) response - will not work with my radio.
David
Posted: Sat Oct 06, 2018 4:59 pm
by W1AEX
David,
Don't be too discouraged at this point in the development process. Apparently, there are still some timing closure issues and logic errors that are being chased out. At this time, my own 200D is not fully functional with the Protocol 2 firmware so I am also a member of the club that's looking forward to the next release. I'm not a programmer but I can definitely respect how tedious it is to get all the Protocol 2 firmware for each model across the ANAN line squared away. Fortunately, I'm very content with how well the Protocol 1 firmware and software behaves so i'm not too anxious about it.
