TAPR Hermes PCB
jim4kfz
TAPR Hermes PCB
Postby jim4kfz » Sat Jul 22, 2023 11:36 am
Hi, I have one of the original TAPR Hermes 10 PCBs. It's working very well with the TAPR firmware with PowerSDR and the Apache labs ANAN -10 PA and housing kit.
I want to upgrade the firmware to 10.7 so that I can use Thetis. Am I likely to get any problems attempting this with one of the original boards.
I think I will use the boot loader and insert a jumper on J12.
I am aware that there might be a problem with F3 after upgrade.
I would appreciate any comments and anything to look out for.
Many Thanks in advance.
Roger (G4KFZ)
n1gp
Re: TAPR Hermes PCB
Postby n1gp » Sat Jul 22, 2023 5:17 pm
Hi Roger,
If you open the unit up you might want to put a heatsink on the Ethernet Phy chip.
It gets a lot warmer running at Gige.
Also note that there are later versions of the P2 firmware. Check out this thread:
https://community.apache-labs.com/viewtopic.php?f=32&t=3310
-Rick / N1GP
Re: TAPR Hermes PCB
Postby w-u-2-o » Sat Jul 22, 2023 6:41 pm
Also, Thetis will run with Protocol 1 firmware in your Hermes. The only restriction is that you can only use 192KHz sample rate with Thetis and Protocol 1.
jim4kfz
Re: TAPR Hermes PCB
Postby jim4kfz » Thu Aug 03, 2023 2:06 pm
Hi, Thanks for the replys, I will do as suggested.
jim4kfz
Re: TAPR Hermes PCB
Postby jim4kfz » Thu Aug 31, 2023 1:24 pm
Hi All, Just an update with the upgrade, all went OK with no problems. I used HPSDRProgrammer_web_v0.2.7_windows. Ive been using it for a few weeks so far with excellent results with Thetis.
Also heatsink fitted to Ethernet chip.
Many thanks to all for the comments and help.
73 Roger (G4KFZ)
Return to “Hermes Firmware (10 & 100)”
