N8RWS wrote:Also, the TX bandwidth error does not occur if sample rate is 192000
Jeff
N8RWS wrote:Good day,
Wondering if anyone found fix for TX bandwidth error in dup mode? The visual in the display looks to be double the bandwidth I am actually running. This occurs only when pure signal is on.
I am running: ANAN 100, V2.8.11~2/V10.8.0, 21k8, Firmware: 2 10.8 pre20
Here are a few points that may help track down this issue. The problem only occurs if RX1 sample rate is over 192000 and PureSignal is fully enabled. If I perform a single cal with two-tone it will lock in, correct and not display double the bandwidth as I am transmitting. As soon as I click the PS button and PureSignal starts sampling it will display double the bandwidth as I am transmitting .
I am still running firmware: 2 10.8 pre20 which is working the best of all releases so far. I am running Thetis v2.9.0.5 but have tried v2.9.0.3 and I reset the database with no change to the problem.
I realize not many are running these old ANAN 100's so this is surely not a priority, it would be sweet if someone could dial in the firmware to address this issue !!
Thank you
Jeff
