Different versions of P2 firmware causing this?
JJ4SDR
Postby JJ4SDR » Tue Mar 18, 2025 5:44 pm
I have two 7000 DLE MKII radios and I believe both have the same FPGA ( EP4CGX150F896 Cyclone IV series FPGA) in them as well although I am not 100% certain. One radio runs on FW v2.1.18 P2 ("radio #1" in the screen-capture below) and radio #2 runs on FW v2.2.2 P2. Note, I tried FW v2.2.2 on radio #1 a long time ago, but went back to FW v2.1.18 as From/To VAC underflows/overflows showed huge numbers acted pretty bad!
Observe 2 "spurs" (for lack of a more appropriate term) when using radio #2. They appear around 15kHz above and below my actual TX frequency. This, regardless of whether I am on CW or SSB or band. Granted that the strength of the "spurs" is fairly low and 99% of the time, they won't be audible. However, why would these rear up their ugly heads only on radio #2? :? The station set-up is identical as I have only swapped radios.
I suppose I could roll back to FW v.2.1.18 on radio #2 and see if that makes any difference!
Comps Radio 1 and 2.jpg (211.58 KiB) Viewed 12646 times
Re: Different versions of P2 firmware causing this?
Postby w-u-2-o » Tue Mar 18, 2025 9:07 pm
You are on the right track. Put the same firmware into both boxes and see if things look similar. You can put both on 2.2.2 or both on 2.1.18, etc.
JJ4SDR
Postby JJ4SDR » Tue Mar 18, 2025 9:47 pm
Thanks Scott!
I already had FW v2.2.2 P2 on radio #1 and it didn't really work very well. Will roll radio #2 back to FW v2.1.18 P2 and see if that makes any difference. With regard to both radios looking "similar," I want them both looking as radio #1 does currently.
Update:
I guess radio #2 does not have the same FPGA that radio #1 has as after rolling back to FW 2.1.18 P2 the Thetis can't find the HW. Is there a later version of FW v.2.2.2 P2 that I might want to try instead?
Update2:
MAJOR PROBLEM cropped up! I tried FW 2.1.26 P2 as from another conversation with Doug (he wasn't a 100% certain which FPGA radio #2 had), surmised that by "going by the firmware v2.2.2 and the circuit board it most likely a EP4CE115F29C8N". Looking at the S/N of radio #2 and the thread at viewtopic.php?f=32&t=4462, FW v.2.1.18 is what radio #2 would like to see!
I then decided to go back to the good-ole FW v2.2.2 P2 and SAME result, Thetis no longer detects the radio! NO FW works on radio #2! :(
I HOPE that I didn't BRICK radio #2. When using Bootloader, it does find the board and before programming it says "Erasing device...." or something like that and that it might take up to 90 seconds......ALL seemed to go well, with no errors reported. Exited, switched OFF radio and put Bootloader switch to OFF position, restarted radio. Thetis can't find radio #2 no matter which P2 FW version I try. I was expecting that Thetis would find the radio with the original FW v2.2.2 P2 programmed into it. :cry:
Update3:
Tried even rolling back to Protocol 1, but no joy. THEN, it hit me, I always hear a RELAY click upon starting Thetis (clicking on the "Power" icon) and there is no click of any kind. Perhaps this is a STUCK relay and has absolutely nothing to do with firmware! Would sure value comments, to save my sanity, again!! :roll: :roll: Also, the right hand red LED stays lit, a solid RED instead of a blinking RED, which indicates the "heart is beating." Put in my radio #1 and all is well! So, I am thinking radio #2 has developed a hardware problem (relay?).
Postby w-u-2-o » Wed Mar 19, 2025 2:53 pm
It seems very unlikely that a hardware problem occurred so coincidentally in the ANAN. Let's assume it has not, for now.
It also seems like there are no basic mistakes being made, i.e. forgetting to move the bootloader switch, things like that.
A surprisingly common issue is a bad Ethernet cable. More than once it has happened that manipulation of the ANAN, for instance to reach the bootloaders switch, has damaged a weak Ethernet cable, but only damaged it in such a way that it no longer will support GigE. Remember that only two pairs are necessary for 100Mbit/s operation (bootloader), but all four pairs must be good for GigE (Thetis). Swap cables, and check for good GigE indications at the PC or switch port the ANAN connects to.
If it's not the cable, then In the spirit of Sherlock Holmes, maybe, just maybe, there was some confusion about what firmware was, and what FPGA is, in #2. It might be worth rolling through the three different versions of firmware for the three different FPGAs just to confirm that this is not a problem.
viewtopic.php?f=32&t=4972
The other thing to look at is to reprogram the IP address in #2 using bootloader. What is your setup for IP addresses on the PC, #1 and #2?
JJ4SDR
Postby JJ4SDR » Wed Mar 19, 2025 6:32 pm
I use CAT8 (overkill) cables. Put in radio #1 in line this morning and all works very well. Using an unmanaged Ethernet switch (have been for more than 3 years now) capable of 1 GBit/s speed.
With regard to P2 FW, I tried several of them. Radio #2 had been running well on FW v2.2.2 for quite a while so I don't think it has to with FW. There is no confusion about the FW at all. I even tried Protocol 1 FW, but no joy.
IP address: Why would the IP address be a problem all of a sudden? I guess it is possible. ;) NOTE: I only have one radio on the network at the same time. I have made copies of AppData\Roaming\OpenHPSDR for both #1 and #2 in a safe place. Now, when I swap radios, I purge out the entire AppData\Roaming\OpenHPSDR for the radio I WAS using from the PC. Before I put the other radio in line, I move the entire AppData\OpenHPSDR Folder for that radio from that "safe place." Is this an incorrect way of doing it?
Below, see Hardware, Network Forms and Bootloader View:
Network Tab #2.jpg (121.35 KiB) Viewed 12331 times
Gen HW Select #2.jpg (115.33 KiB) Viewed 12331 times
JJ4SDR
Postby JJ4SDR » Thu Mar 20, 2025 12:18 am
I tried using Static IP address as well, just for grins, but no joy :cry: !
After having flashed a FW version on it and having switched the bootloader to the OFF position (included in the FW versions, v2.2.2 that worked beautifully just a few days ago) and powering up the ANAN, the right red LED stays solid, no blinking. It is blinking when I use the Bootloader to flash the FW as I believe it should.
As soon as I see that solid right red LED, with no "heart-beat," I know that Thetis won't detect the hardware. Also, there is no audible click when I am starting up Thetis. According to Doug: "That’s the firmware setting the relays to a known configuration. If the firmware is not running then no relay setup." (and, so no click/my add!). => So, the firmware(s) that I have flashed are not "running." :(
Update:
Bootloader switch is working. Switched it to OFF position, went into Bootloader and it didn't find the radio (board). Another good friend suggested that I check if all of the SMA connectors are snug. It is just such a bear doing that...... ;)
Postby w-u-2-o » Thu Mar 20, 2025 8:52 pm
Does the Bootloader still find the board, or has that started failing, too?
JJ4SDR
Postby JJ4SDR » Thu Mar 20, 2025 9:27 pm
Scott!
I am a happy camper! :D
Spoke with 2 other fellows about this as well. And, I must give Doug many thanks :) :) ! He was incredibly generous with his time and suggestions! It seems that the FPGA is a Cyclone V series one to boot which belies the S/N on the bottom of the radio. Some repair had been done in the radio so that threw me completely.
Your comment about the IP address did the trick! For a foolish reason - yes, I am not afraid to man up to that - when tried using Static IP at one juncture I likely reprogrammed radio #2 with the "wrong" address. I corrected that by putting all ZEROs in the IP address field and I am using Dynamic IP. Perhaps learning from my mistakes might benefit someone else.
Below, see results from tests I ran today. Now, I am hoping to settle on a working FW (not going to Protocol 1 though!) that will not generate those "spurs" that I reported in the first post.
Update: Made a mistake in the Excel table, but included the correct one below. The spurs are still there for all the working versions of FW though! No change at all. Also, CW is either "dirty" or "clean" depending on the FW used. "Surprisingly," I see "dirty" CW gets "cleaner" when PureSignal is engaged :? ! I was under the impression that PureSignal mainly improved SSB transmissions.
Update on FW Tests on Radio #2.jpg (106.12 KiB) Viewed 11712 times
JJ4SDR
Re: S-Meter Calibration
Postby JJ4SDR » Fri Mar 21, 2025 12:29 am
w-u-2-o wrote:You cannot use readings from the panadapter to determine S-units except for CW:
https://apache-labs.com/community/viewt ... f=6&t=2463
My old Flex 3000, and now the ANAN, finally made me "comfortable", because RF system design is my day job. I despise the so-called metering on KenYaeCom equipment.
Your comments regarding panadapter readings on CW vs S-units caught my eye! As you remember from my other post in another forum, I included a screen-capture (included here, for convenience), I am concerned over "spurs" I am seeing, both on CW and SSB. Radio #1 is MUCH cleaner than radio #2! Compounding the situation is that I suffer from OCD ;) ! What is shown below is when I operate SSB.
Q1: See those 2 "spurs" around 15kHz above and below my TX frequency. From earlier threads having to do with PureSignal, I seem to recall that spurs like these will likely not be either seen or heard by anyone. Let's assume that I talk to a local fellow on 40 meters and I am S-9/+40dB at his station. Wouldn't he be able to hear/see those "spurs?" I will read the thread where you are discussing the difference between S meter readings and the levels in the Panadapter that you also posted in this thread.
Q2: When I am on CW, I can see these "spurs" as well and they are approximately -65dBc from my TX frequency. Wouldn't that mean those "spurs" can be easily heard by someone else in case I am putting out a very powerful signal. Say S-9/+40dB again!
I am thinking that especially on CW, I would be using a transceiver that will not pass FCC regulations......but, I think I need to revisit those!
Can you alleviate my concerns and worry? :roll: ;)
Comps Radio 1 and 2.jpg (211.58 KiB) Viewed 11671 times
Postby w-u-2-o » Fri Mar 21, 2025 1:16 pm
JJ4SDR wrote:Scott!
As I had suggested two days ago, when I wrote "then In the spirit of Sherlock Holmes, maybe, just maybe, there was some confusion about what firmware was, and what FPGA is, in #2. It might be worth rolling through the three different versions of firmware for the three different FPGAs just to confirm that this is not a problem".
This is all a matter of how well the timing is closing in the FPGA as part of the physical gate floorplan, which will obviously be different in both FPGA variants, and a factor of minor differences between circuit boards. Hence it is not surprising that #1 and #2 provide different performance.
RF chain linearity plays an important part in the spectral purity of the output regardless of what type of signal is being transmitted. However, as you note, any non-linearities become much more noticeable with a multi-tone waveform, and SSB phone is pretty much the worst case in that respect.
JJ4SDR
Postby JJ4SDR » Fri Mar 21, 2025 2:30 pm
I appreciate your comments. In another thread on "S meter calibration" - viewtopic.php?f=9&t=3981&p=31655&hilit=s+meter+calbration#p31655 - I also touched on the level of "spurs" (CW vs SSB) and my concerns. I am not sure if there is really anything else I can do in an effort to get rid of those "spurs."
Postby w-u-2-o » Sat Mar 22, 2025 2:47 pm
JJ4SDR wrote:Q1: See those 2 "spurs" around 15kHz above and below my TX frequency. From earlier threads having to do with PureSignal, I seem to recall that spurs like these will likely not be either seen or heard by anyone. Let's assume that I talk to a local fellow on 40 meters and I am S-9/+40dB at his station. Wouldn't he be able to hear/see those "spurs?" I will read the thread where you are discussing the difference between S meter readings and the levels in the Panadapter that you also posted in this thread.
Some assumptions and approximations are necessary to make this calculation in a straightforward way.
- The other fellow is using a similar radio, e.g. a Flex or an openHPSDR type radio like Apache
- Let's assume a conservative 2700Hz receive passband
- Let's approximate your SSB phone signal as having a nominally flat spectrum across that 2700Hz
Obviously the other station will not hear them because they are well outside any reasonable receive passband width, even if it's set to 10KHz wide.
Will he see them? Let's do some math. Your S9+40 signal equates to -73 + 40 dBm, or -33 dBm in a 2700Hz passband. We have to scale that to the resolution bandwidth of the spectral display, let's say 3Hz. Rounding to the nearest dB, 2700Hz = 34dBHz, 3Hz = 5dBHz, thus your main signal in the passband will be peaking around -33dBm (2700Hz) - (34-5dBHz) = -62 dBm on the spectral display.
With those spurs being approximately -50dBc, that means they'll be around -112dBm on the spectral display. Without going through more math, he'll see those starting to poke above the noise floor with an S7 noise level (again, in a 2700Hz passband).
Maybe not "easily". Achieving +40 at another station is not typical.
From a US regulatory perspective there is no problem. See https://www.ecfr.gov/current/title-47/section-97.307, specifically sub-part (d).
JJ4SDR
Postby JJ4SDR » Sat Mar 22, 2025 8:57 pm
Your consistent feedback is very much appreciated. Will look at the math in detail.
When I am talking S-9/+40dB, I am referring mostly to local contacts on 40m where I am extremely strong, on receivers with calibrated S meters. On 20, I also do get very strong signal reports, +30dB every now and then and obviously, depending on the RX at the receiving end, my signal may be actually way less than that!
It is just that it "bothers" me that radio #2 is not as clean as radio #1 which is VERY clean in comparison!
JJ4SDR
Postby JJ4SDR » Fri May 23, 2025 4:18 pm
UPDATE:
Note that the "spurs" I have been alluding to appear around 15kHz above and below my actual TX frequency (regardless of whether I am on SSB or CW). They don't appear when operating barefoot, only when the amp is in line.
Warren emailed me in March a couple of times (see relevant partials below):
[i]"I cannot be 100% sure; however, normally these kinds of spurs are just related to firmware. I do not think that there is any hardware problem. A different FPGA chip, with different timing, MIGHT help; however, the best solution would be in firmware.
These “images” are created in the decimation process in firmware and the firmware should filter them out. However, if it is not working exactly correctly, sometimes the images remain."
"I think that is most likely that these images are being generated by the firmware in the receive chain because the DUP display is just “receiving” the transmitted output. However, it is possible that the images are being generated in the transmitter chain which means they would also be transmitted.
The best way to check is to receive your transmitted signal with another radio, OR, use a spectrum analyzer on the transmitter output (with appropriate attenuation), OR, have a nearby ham check your transmitted signal.
"[/i]
Put SDRPlay (with no antenna connected to it, for some serious "attenuation") in line this morning, to conduct additional testing. Noise-floor at around ZERO (about -133dBm, according to UNO, the software running on the SDRplay) and my CW signal registering around -65dBm. Ran 1.4kW on CW on a couple of bands with my signal strength being about -65dBm. "Spurs" not visible or audible at all so, I think I am safe in assuming that there is no issue with hardware but rather "the firmware is not "filtering them out," to quote Warren's messages to me. :D
I also did some testing with a local ham who also has an ANAN (on 40m SSB) who didn't hear/see anything. From memory, the noise-floor on my end was around S-9, but can't remember what it was at his location which obviously figures into whether he can hear/see those "spurs." This morning I also listened to/watched myself via WebSDR that hears me very well (at almost +30dB/S-9) with a noise-floor at around S-5. Nothing heard/visible.
In "conclusion," I am optimistically thinking that the issue lies with firmware, not hardware :) ;) !
n1gp
Postby n1gp » Wed May 28, 2025 8:08 pm
Hi Juha and All,
I tested with my MKIII CV and could not reproduce your issue with 2.2.2 or earlier.
I am running 100W barefoot as I do not have an AMP.
I saw this thread and would like you to try the latest MKIII CV image I have.
I made some changes back in Feb. that I have not distributed yet due to lack of
testing. However if you wouldn't mind giving it a go, I'd like to see how it works for
you on your MKIII CV model 7000. There are no DSP changes, but who knows, maybe
it will make a difference.
Link:
https://www.dropbox.com/scl/fi/nyypud0p1d2o5zjti60cm/Metis_Orion_MkIII_CV_P2_v2.2.3.rbf?rlkey=cp0y2b2z4eoyp3hn0pl20a8q3&st=r5npqb2l&dl=0
Changes:
2025 Feb 15 - (N1GP) Added keyout to bit 7 of CC_encoder data byte 0. This can be used to
generate a sidetone on the client software. Also now latching ADC0 & ADC1 overload
so if it happens only once it gets sent in CC_encoder. CC_encoder was sending
every 50ms, now every 200ms unless PTT or realtime events.
-Rick / N1GP
JJ4SDR
Postby JJ4SDR » Wed May 28, 2025 11:24 pm
Hi Rick,
Very curious and intrigued by your response.
NOTE:
I do not see any of those "spurs" when I run bare-foot! As soon as I put the amp in line, I do see them. The spurs aren't there when I put my other 7000 in line. Perhaps, I give this version a shot, just the same ;) ! My problem is that I am a bit of "perfectionist!"
What say?
UPDATE:
I just tried it and unfortunately I don't see any difference ;) ! THANK you for letting me have first dibs on your product Rick!! :D
Incidentally, I noticed that my "signature" had the SW/FW versions in it that go with my other 7000 ;) !
n1gp
Postby n1gp » Thu May 29, 2025 7:41 pm
Juha,
Tnx for giving this FW a shot and reporting back.
Sorry to hear it didn't fix your spur issue.
-Rick / N1GP
JJ4SDR
Postby JJ4SDR » Thu May 29, 2025 8:15 pm
Rick,
I value your time.
Incidentally, I noticed - upon additional testing - that on 10 and 17 (from memory) I do see the 2 "spurs" when the amp is not in line when I transmit a carrier, using "TUN". None to be seen when I was on 40, 20 or 15. But, again, the experiment with SDRPlay in line did not show any of them appearing in the Panafall so, perhaps I just just making a mountain out of a mole hill.......
UPDATE:
I see them on 10 and 17 at around -93dBm and much stronger with the amp on, at around -70/-75dBm. These levels, only when I use the "TUN" button. On SSB, even with the amp in line, the peaks sometimes reach "only" around -80dBm on 40,20,17,15 and 10.
One reason for my having spent all this time on this is that I may put this radio up sale. At least, I would have a clean conscience and perhaps, those "phantom" spurs will vanish with some new firmware version.
Roger GT
Postby Roger GT » Fri May 30, 2025 1:46 pm
Hi experts,
I also carried out the test with the spurs.
My TRX is an ANAN G2 with a 7" display and the latest
Firmware (FPGA and piHPSDR). I can see the spurs
at 15 kHz intervals above and below. Everything is OK with the TRX without the power amplifier (PA), but with the PA, the spurs are clearly visible. This is just a quick test at 3.6 MHz. I will conduct further tests.
Vy 73 Roger DL2YDP
JJ4SDR
Postby JJ4SDR » Fri May 30, 2025 5:36 pm
Hi Roger,
Thank you for your post. I would be very interested in learning about your findings.
I am not familiar with the G2 at all so I have no idea of how many firmware versions are currently available and if bouncing between them makes any difference! Out of curiosity, it would be awesome if someone up on the G2 would tell if they all sport the same FPGA? From what I understand, different FPGAs require appropriate firmware versions, at least if what I see in the 7000 models is anything to go by.
Viele Gruesse!
(OH1HX, ex 7J1AXO)
Roger GT
Postby Roger GT » Sat May 31, 2025 8:52 pm
As far as I know, all G2s have an FPGA XC7A200T. (Correct me if I'm wrong).
There is also only one firmware which is available from G8NJJ Laurence Barker (FPGA) and DL1YCF Christoph van Wüllen (piHPSDR).
In piHPSDR, you can choose between a display of 7", 8" or no display.
New measurements without PA!
160m spurs +- ~24kHz
80m OK :?
60m spurs +- ~24kHz
40m spurs +- ~24kHz
30m spurs +- ~24kHz
20m spurs +- ~24kHz
17m spurs +- ~24kHz
15m spurs +- ~24kHz
12m spurs +- ~24kHz
10m spurs +- ~24kHz
6m spurs +- ~24kHz
To see the spurs, just press the Tune button! Two-tone is not required!
Vy 73 Roger DL2YDP
JJ4SDR
Postby JJ4SDR » Mon Jun 02, 2025 11:39 am
I appreciate the response Roger!
