Monitor: 60Hz vs 144Hz
Posted: Thu May 02, 2024 4:08 pm
by WT4DX
For those that may been down this path already, do you see much difference in Thetis with a 60Hz versus a 144Hz monitor?
Tem
WT4DX
Re: Monitor: 60Hz vs 144Hz
Posted: Thu May 02, 2024 4:52 pm
With the bottleneck being the FFT processing, it's unlikely you can get Thetis to run much faster than 60Hz at 384KHz or larger IF bandwidth. Thus a faster display is wasted on Thetis, but you may find it valuable for gaming.
Posted: Thu May 02, 2024 6:55 pm
by WT4DX
My initial impression was that the 60Hz monitor would be sufficient, but I wasn't 100% sure.
The monitor for the radio has been moved to my home office, so I'm looking at a new monitor.
Tem
WT4DX
