G2 Updated files and simplified update procedure
n1gp
Re: G2 Updated files and simplified update procedure
Postby n1gp » Sat Feb 01, 2025 8:45 pm
@w-u-2-o
@KC2QMA
It was recently discovered that the Open Collector outputs were not as previously
documented. This only affects the G2.
Old pin assignment:
New pin assignment:
Updated G2 Manual:
https://apache-labs.com/download_file.php?downloads_id=1023
KC2QMA
Postby KC2QMA » Sat Feb 01, 2025 8:59 pm
So I need to figure out and re-map the pin assignments in Thetis Or make a new cable?
I see even the darn Ground pin is different!
Just want to make sure i understand.
n1gp
Postby n1gp » Sun Feb 02, 2025 8:38 am
I would probably re-make my cable.
As for your pihpsdr issue, can you try typing in, and post back the output
of those commands?
cd ~/github/pihpsdr
make clean
git remote -v
git pull
make
ls -l
Postby w-u-2-o » Sun Feb 02, 2025 2:08 pm
Wow :roll:
Rick--if you would please make a separate, dedicated post in the G2 forum that describes this then I will make sure it becomes a tacked/sticky post for everyone to easily reference.
Has this been reflected in the G2 documentation?
Postby w-u-2-o » Sun Feb 02, 2025 2:09 pm
Wow. Can't believe Apache made that mistake :roll:
n1gp
Postby n1gp » Sun Feb 02, 2025 4:00 pm
@w-u-2-o
Scott, I posted an update in the G2 forum.
Ya, there's also a link in it to the updated G2 manual.
KC2QMA
Postby KC2QMA » Sun Feb 02, 2025 4:17 pm
Good thing I didn't blow up my amp! :oops:
KC2QMA
Postby KC2QMA » Sun Feb 02, 2025 4:34 pm
New Title for Post:
"G2 Updated files and NOT simple update procedures"
KC2QMA
Postby KC2QMA » Mon Feb 03, 2025 12:23 pm
n1gp wrote:I would probably re-make my cable.
of those commands?
cd ~/github/pihpsdr
make clean
git remote -v
git pull
make
ls -l
Sort of fixed it, I can run if open the app from the pihpsdr folder.
But No desktop icon and the icon in the start menu under other programs doesn't work.
pi@raspberrypi:~ $ cd ~/github/pihpsdr
pi@raspberrypi:~/github/pihpsdr $ make clean
rm -f *.o
rm -f pihpsdr hpsdrsim bootloader
rm -rf pihpsdr.app
pi@raspberrypi:~/github/pihpsdr $ git remote -v
origin https://github.com/dl1ycf/pihpsdr.git (fetch)
origin https://github.com/dl1ycf/pihpsdr.git (push)
pi@raspberrypi:~/github/pihpsdr $ git pull
remote: Enumerating objects: 61, done.
remote: Counting objects: 100% (39/39), done.
remote: Compressing objects: 100% (20/20), done.
remote: Total 61 (delta 28), reused 29 (delta 19), pack-reused 22 (from 1)
Unpacking objects: 100% (61/61), done.
From https://github.com/dl1ycf/pihpsdr
7c99502a..16c60f5c master -> origin/master
40ce9a9c..ece1a9d7 SERVER -> origin/SERVER
* [new tag] v2.5 -> v2.5
*** Please tell me who you are.
Run
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
to set your account's default identity.
Omit --global to set the identity only in this repository.
fatal: unable to auto-detect email address (got 'pi@raspberrypi.(none)')
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o MacOS.o MacOS.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o about_menu.o about_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o actions.o actions.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o action_dialog.o action_dialog.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o agc_menu.o agc_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o ant_menu.o ant_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o band.o band.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o band_menu.o band_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o bandstack_menu.o bandstack_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o button_text.o button_text.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o configure.o configure.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o css.o css.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o cw_menu.o cw_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o cwramp.o cwramp.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o discovered.o discovered.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o discovery.o discovery.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o display_menu.o display_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o diversity_menu.o diversity_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o encoder_menu.o encoder_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o equalizer_menu.o equalizer_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o exit_menu.o exit_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o ext.o ext.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o fft_menu.o fft_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o filter.o filter.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o filter_menu.o filter_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o gpio.o gpio.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o iambic.o iambic.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o i2c.o i2c.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o led.o led.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o main.o main.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o meter.o meter.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o meter_menu.o meter_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o mode.o mode.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o mode_menu.o mode_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o new_discovery.o new_discovery.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o new_menu.o new_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o new_protocol.o new_protocol.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o noise_menu.o noise_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o oc_menu.o oc_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o old_discovery.o old_discovery.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o old_protocol.o old_protocol.c
old_protocol.c: In function ‘process_control_bytes’:
old_protocol.c:930:44: warning: suggest parentheses around arithmetic in operand of ‘|’ [-Wparentheses]
average_current=(3*average_current +((control_in[3]&0xFF)<<8)|(control_in[4]&0xFF)) >> 2;
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o pa_menu.o pa_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o property.o property.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o protocols.o protocols.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o ps_menu.o ps_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o radio.o radio.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o radio_menu.o radio_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o receiver.o receiver.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o rigctl.o rigctl.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o rigctl_menu.o rigctl_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o rx_menu.o rx_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o rx_panadapter.o rx_panadapter.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o sintab.o sintab.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o sliders.o sliders.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o store.o store.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o store_menu.o store_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o switch_menu.o switch_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o toolbar.o toolbar.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o toolbar_menu.o toolbar_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o transmitter.o transmitter.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o tx_menu.o tx_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o tx_panadapter.o tx_panadapter.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o version.o version.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o vfo.o vfo.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o vfo_menu.o vfo_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o vox.o vox.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o vox_menu.o vox_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o xvtr_menu.o xvtr_menu.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o waterfall.o waterfall.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o zoompan.o zoompan.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o pulseaudio.o pulseaudio.c
pulseaudio.c: In function ‘audio_open_output’:
pulseaudio.c:161:59: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 4 has type ‘unsigned int’ [-Wformat=]
g_print("%s: allocated local_audio_buffer %p size %ld bytes\n",__FUNCTION__,rx->local_audio_buffer,2*out_buffer_size*sizeof(float));
%d
In function ‘sink_list_cb.part.0’,
inlined from ‘sink_list_cb’ at pulseaudio.c:65:13:
pulseaudio.c:73:5: warning: ‘strncpy’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
strncpy(output_devices[n_output_devices].name,s->name,strlen(s->name));
pulseaudio.c:75:5: warning: ‘strncpy’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
strncpy(output_devices[n_output_devices].description,s->description,strlen(s->description));
In function ‘source_list_cb.part.1’,
inlined from ‘source_list_cb’ at pulseaudio.c:49:13:
pulseaudio.c:57:5: warning: ‘strncpy’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
strncpy(input_devices[n_input_devices].name,s->name,strlen(s->name));
pulseaudio.c:59:5: warning: ‘strncpy’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
strncpy(input_devices[n_input_devices].description,s->description,strlen(s->description));
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o alsa_midi.o alsa_midi.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o midi2.o midi2.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o midi3.o midi3.c
cc -O3 -Wno-deprecated-declarations -Wall -D MIDI -D GPIO -D OLD_GPIOD -DPULSEAUDIO -D GIT_DATE='"2023-07-05"' -D GIT_VERSION='"2.0-DL1YCF"' `pkg-config --cflags gtk+-3.0` -c -o midi_menu.o midi_menu.c
cc -o pihpsdr MacOS.o about_menu.o actions.o action_dialog.o agc_menu.o ant_menu.o band.o band_menu.o bandstack_menu.o button_text.o configure.o css.o cw_menu.o cwramp.o discovered.o discovery.o display_menu.o diversity_menu.o encoder_menu.o equalizer_menu.o exit_menu.o ext.o fft_menu.o filter.o filter_menu.o gpio.o iambic.o i2c.o led.o main.o meter.o meter_menu.o mode.o mode_menu.o new_discovery.o new_menu.o new_protocol.o noise_menu.o oc_menu.o old_discovery.o old_protocol.o pa_menu.o property.o protocols.o ps_menu.o radio.o radio_menu.o receiver.o rigctl.o rigctl_menu.o rx_menu.o rx_panadapter.o sintab.o sliders.o store.o store_menu.o switch_menu.o toolbar.o toolbar_menu.o transmitter.o tx_menu.o tx_panadapter.o version.o vfo.o vfo_menu.o vox.o vox_menu.o xvtr_menu.o waterfall.o zoompan.o pulseaudio.o \
alsa_midi.o midi2.o midi3.o midi_menu.o -lpulse-simple -lpulse -lpulse-mainloop-glib `pkg-config --libs gtk+-3.0` -lgpiod -li2c -lasound -lwdsp -lpthread -lm -lrt
pi@raspberrypi:~/github/pihpsdr $ ls -l
total 3956
-rw-r--r-- 1 pi pi 4518 Jul 5 2023 about_menu.c
-rw-r--r-- 1 pi pi 804 Jul 5 2023 about_menu.h
-rw-r--r-- 1 pi pi 5056 Feb 3 07:20 about_menu.o
-rw-r--r-- 1 pi pi 2926 Jul 5 2023 action_dialog.c
-rw-r--r-- 1 pi pi 61 Jul 5 2023 action_dialog.h
-rw-r--r-- 1 pi pi 3720 Feb 3 07:20 action_dialog.o
-rw-r--r-- 1 pi pi 47046 Dec 1 14:37 actions.c
-rw-r--r-- 1 pi pi 2997 Dec 1 14:37 actions.h
-rw-r--r-- 1 pi pi 28040 Feb 3 07:20 actions.o
-rw-r--r-- 1 pi pi 1393 Jul 5 2023 adc.h
-rw-r--r-- 1 pi pi 884 Jul 5 2023 agc.h
-rw-r--r-- 1 pi pi 4944 Dec 1 14:37 agc_menu.c
-rw-r--r-- 1 pi pi 802 Jul 5 2023 agc_menu.h
-rw-r--r-- 1 pi pi 5300 Feb 3 07:20 agc_menu.o
-rw-r--r-- 1 pi pi 5909 Jul 5 2023 alex.h
-rw-r--r-- 1 pi pi 13388 Jul 5 2023 alsa_midi.c
-rw-r--r-- 1 pi pi 219 Jul 5 2023 alsa_midi.h
-rw-r--r-- 1 pi pi 6768 Feb 3 07:21 alsa_midi.o
-rw-r--r-- 1 pi pi 13660 Dec 1 14:37 ant_menu.c
-rw-r--r-- 1 pi pi 795 Jul 5 2023 ant_menu.h
-rw-r--r-- 1 pi pi 9364 Feb 3 07:20 ant_menu.o
-rw-r--r-- 1 pi pi 5727 Dec 1 14:37 appearance.h
-rw-r--r-- 1 pi pi 26956 Jul 5 2023 audio.c
-rw-r--r-- 1 pi pi 1584 Jul 5 2023 audio.h
-rw-r--r-- 1 pi pi 25917 Dec 1 14:37 band.c
-rw-r--r-- 1 pi pi 2749 Jul 5 2023 band.h
-rw-r--r-- 1 pi pi 3945 Jul 5 2023 band_menu.c
-rw-r--r-- 1 pi pi 878 Jul 5 2023 band_menu.h
-rw-r--r-- 1 pi pi 4120 Feb 3 07:20 band_menu.o
-rw-r--r-- 1 pi pi 19416 Feb 3 07:20 band.o
-rw-r--r-- 1 pi pi 1423 Jul 5 2023 bandstack.h
-rw-r--r-- 1 pi pi 4246 Jul 5 2023 bandstack_menu.c
-rw-r--r-- 1 pi pi 808 Jul 5 2023 bandstack_menu.h
-rw-r--r-- 1 pi pi 4320 Feb 3 07:20 bandstack_menu.o
-rw-r--r-- 1 pi pi 10849 Jul 5 2023 bootldrsim.c
-rw-r--r-- 1 pi pi 16219 Jul 5 2023 bootloader.c
-rw-r--r-- 1 pi pi 2880 Jul 5 2023 button_text.c
-rw-r--r-- 1 pi pi 109 Jul 5 2023 button_text.h
-rw-r--r-- 1 pi pi 2396 Feb 3 07:20 button_text.o
-rw-r--r-- 1 pi pi 1107 Jul 5 2023 channel.h
-rw-r--r-- 1 pi pi 100577 Jul 5 2023 client_server.c
-rw-r--r-- 1 pi pi 12840 Jul 5 2023 client_server.h
-rw-r--r-- 1 pi pi 10132 Jul 5 2023 configure.c
-rw-r--r-- 1 pi pi 872 Jul 5 2023 configure.h
-rw-r--r-- 1 pi pi 9268 Feb 3 07:20 configure.o
drwxr-xr-x 2 pi pi 4096 Jul 5 2023 controller
-rw-r--r-- 1 pi pi 18093 Jul 5 2023 COPYING
-rw-r--r-- 1 pi pi 1442 Dec 1 14:37 css.c
-rw-r--r-- 1 pi pi 47 Jul 5 2023 css.h
-rw-r--r-- 1 pi pi 2240 Feb 3 07:20 css.o
-rw-r--r-- 1 pi pi 10082 Jul 5 2023 cw_menu.c
-rw-r--r-- 1 pi pi 801 Jul 5 2023 cw_menu.h
-rw-r--r-- 1 pi pi 9592 Feb 3 07:20 cw_menu.o
-rw-r--r-- 1 pi pi 72342 Jul 5 2023 cwramp.c
-rw-r--r-- 1 pi pi 10876 Feb 3 07:20 cwramp.o
-rw-r--r-- 1 pi pi 859 Jul 5 2023 dac.h
-rw-r--r-- 1 pi pi 882 Jul 5 2023 discovered.c
-rw-r--r-- 1 pi pi 4844 Dec 1 14:37 discovered.h
-rw-r--r-- 1 pi pi 868 Feb 3 07:20 discovered.o
-rw-r--r-- 1 pi pi 19854 Dec 1 14:37 discovery.c
-rw-r--r-- 1 pi pi 853 Jul 5 2023 discovery.h
-rw-r--r-- 1 pi pi 10804 Feb 3 07:20 discovery.o
-rw-r--r-- 1 pi pi 17643 Jul 5 2023 display_menu.c
-rw-r--r-- 1 pi pi 806 Jul 5 2023 display_menu.h
-rw-r--r-- 1 pi pi 12996 Feb 3 07:20 display_menu.o
-rw-r--r-- 1 pi pi 8961 Jul 5 2023 diversity_menu.c
-rw-r--r-- 1 pi pi 915 Jul 5 2023 diversity_menu.h
-rw-r--r-- 1 pi pi 9320 Feb 3 07:20 diversity_menu.o
-rw-r--r-- 1 pi pi 32136 Jul 6 2023 E4-5F-01-87-FA-C1.props
-rw-r--r-- 1 pi pi 17772 Jul 5 2023 encoder_menu.c
-rw-r--r-- 1 pi pi 900 Jul 5 2023 encoder_menu.h
-rw-r--r-- 1 pi pi 11520 Feb 3 07:20 encoder_menu.o
-rw-r--r-- 1 pi pi 11457 Jul 5 2023 equalizer_menu.c
-rw-r--r-- 1 pi pi 824 Jul 5 2023 equalizer_menu.h
-rw-r--r-- 1 pi pi 11316 Feb 3 07:20 equalizer_menu.o
-rw-r--r-- 1 pi pi 4209 Jul 5 2023 exit_menu.c
-rw-r--r-- 1 pi pi 70 Jul 5 2023 exit_menu.h
-rw-r--r-- 1 pi pi 3944 Feb 3 07:20 exit_menu.o
-rw-r--r-- 1 pi pi 2928 Dec 1 14:37 ext.c
-rw-r--r-- 1 pi pi 2021 Jul 5 2023 ext.h
-rw-r--r-- 1 pi pi 1964 Feb 3 07:20 ext.o
-rw-r--r-- 1 pi pi 5304 Jul 5 2023 fft_menu.c
-rw-r--r-- 1 pi pi 795 Jul 5 2023 fft_menu.h
-rw-r--r-- 1 pi pi 3776 Feb 3 07:20 fft_menu.o
-rw-r--r-- 1 pi pi 21403 Jul 5 2023 filter.c
-rw-r--r-- 1 pi pi 1586 Jul 5 2023 filter.h
-rw-r--r-- 1 pi pi 10706 Jul 5 2023 filter_menu.c
-rw-r--r-- 1 pi pi 843 Jul 5 2023 filter_menu.h
-rw-r--r-- 1 pi pi 8552 Feb 3 07:20 filter_menu.o
-rw-r--r-- 1 pi pi 13336 Feb 3 07:20 filter.o
-rw-r--r-- 1 pi pi 37011 Dec 1 14:37 gpio.c
-rw-r--r-- 1 pi pi 2320 Dec 1 14:37 gpio.h
-rw-r--r-- 1 pi pi 21664 Feb 3 07:20 gpio.o
-rw-r--r-- 1 pi pi 10891 Jul 6 2023 gpio.props
-rw-r--r-- 1 pi pi 780 Jul 5 2023 hercules.midi.inp
-rw-r--r-- 1 pi pi 71500 Jul 5 2023 hpsdrsim.c
-rw-r--r-- 1 pi pi 3189 Jul 5 2023 hpsdrsim.h
-rw-r--r-- 1 pi pi 4967 Jul 5 2023 i2c.c
-rw-r--r-- 1 pi pi 189 Jul 5 2023 i2c.h
-rw-r--r-- 1 pi pi 3596 Feb 3 07:20 i2c.o
-rw-r--r-- 1 pi pi 23969 Jul 5 2023 iambic.c
-rw-r--r-- 1 pi pi 307 Jul 5 2023 iambic.h
-rw-r--r-- 1 pi pi 5520 Feb 3 07:20 iambic.o
-rw-r--r-- 1 pi pi 1525 Jul 5 2023 led.c
-rw-r--r-- 1 pi pi 873 Jul 5 2023 led.h
-rw-r--r-- 1 pi pi 1668 Feb 3 07:20 led.o
-rw-r--r-- 1 pi pi 11982 Dec 1 14:37 mac_midi.c
drwxr-xr-x 2 pi pi 4096 Jul 5 2023 MacOS
-rw-r--r-- 1 pi pi 4095 Jul 5 2023 MacOS.c
-rw-r--r-- 1 pi pi 2476 Jul 5 2023 MacOS.h
-rw-r--r-- 1 pi pi 760 Feb 3 07:20 MacOS.o
-rw-r--r-- 1 pi pi 9546 Jul 5 2023 main.c
-rw-r--r-- 1 pi pi 1246 Jul 5 2023 main.h
-rw-r--r-- 1 pi pi 9072 Feb 3 07:20 main.o
-rw-r--r-- 1 pi pi 15566 Dec 1 14:37 Makefile
-rw-r--r-- 1 pi pi 19281 Jul 5 2023 meter.c
-rw-r--r-- 1 pi pi 1032 Jul 5 2023 meter.h
-rw-r--r-- 1 pi pi 4859 Jul 5 2023 meter_menu.c
-rw-r--r-- 1 pi pi 798 Jul 5 2023 meter_menu.h
-rw-r--r-- 1 pi pi 4832 Feb 3 07:20 meter_menu.o
-rw-r--r-- 1 pi pi 13040 Feb 3 07:20 meter.o
-rw-r--r-- 1 pi pi 16985 Jul 5 2023 midi2.c
-rw-r--r-- 1 pi pi 8084 Feb 3 07:21 midi2.o
-rw-r--r-- 1 pi pi 928 Dec 1 14:37 midi3.c
-rw-r--r-- 1 pi pi 968 Feb 3 07:21 midi3.o
-rw-r--r-- 1 pi pi 5046 Dec 1 14:37 midi.h
-rw-r--r-- 1 pi pi 54233 Jul 5 2023 midi_menu.c
-rw-r--r-- 1 pi pi 966 Jul 5 2023 midi_menu.h
-rw-r--r-- 1 pi pi 36720 Feb 3 07:21 midi_menu.o
-rw-r--r-- 1 pi pi 896 Jul 5 2023 mode.c
-rw-r--r-- 1 pi pi 990 Jul 5 2023 mode.h
-rw-r--r-- 1 pi pi 3213 Jul 5 2023 mode_menu.c
-rw-r--r-- 1 pi pi 803 Jul 5 2023 mode_menu.h
-rw-r--r-- 1 pi pi 3944 Feb 3 07:20 mode_menu.o
-rw-r--r-- 1 pi pi 1140 Feb 3 07:20 mode.o
-rw-r--r-- 1 pi pi 15335 Dec 1 14:37 new_discovery.c
-rw-r--r-- 1 pi pi 846 Jul 5 2023 new_discovery.h
-rw-r--r-- 1 pi pi 6744 Feb 3 07:20 new_discovery.o
-rw-r--r-- 1 pi pi 36076 Jul 5 2023 newhpsdrsim.c
-rw-r--r-- 1 pi pi 15668 Dec 1 14:37 new_menu.c
-rw-r--r-- 1 pi pi 920 Jul 5 2023 new_menu.h
-rw-r--r-- 1 pi pi 15804 Feb 3 07:20 new_menu.o
-rw-r--r-- 1 pi pi 69875 Dec 1 14:37 new_protocol.c
-rw-r--r-- 1 pi pi 3190 Dec 1 14:37 new_protocol.h
-rw-r--r-- 1 pi pi 27376 Feb 3 07:20 new_protocol.o
-rw-r--r-- 1 pi pi 23221 Jul 5 2023 noise_menu.c
-rw-r--r-- 1 pi pi 866 Jul 5 2023 noise_menu.h
-rw-r--r-- 1 pi pi 15076 Feb 3 07:20 noise_menu.o
-rw-r--r-- 1 pi pi 8692 Jul 5 2023 oc_menu.c
-rw-r--r-- 1 pi pi 801 Jul 5 2023 oc_menu.h
-rw-r--r-- 1 pi pi 7776 Feb 3 07:20 oc_menu.o
-rw-r--r-- 1 pi pi 20657 Jul 5 2023 old_discovery.c
-rw-r--r-- 1 pi pi 909 Jul 5 2023 old_discovery.h
-rw-r--r-- 1 pi pi 8224 Feb 3 07:20 old_discovery.o
-rw-r--r-- 1 pi pi 69298 Jul 5 2023 old_protocol.c
-rw-r--r-- 1 pi pi 1181 Jul 5 2023 old_protocol.h
-rw-r--r-- 1 pi pi 23452 Feb 3 07:20 old_protocol.o
-rw-r--r-- 1 pi pi 18878 Jul 5 2023 ozyio.c
-rw-r--r-- 1 pi pi 3145 Dec 1 14:37 ozyio.h
-rw-r--r-- 1 pi pi 9840 Jul 5 2023 pa_menu.c
-rw-r--r-- 1 pi pi 862 Jul 5 2023 pa_menu.h
-rw-r--r-- 1 pi pi 12280 Feb 3 07:20 pa_menu.o
-rwxr-xr-x 1 pi pi 558476 Feb 3 07:21 pihpsdr
-rw-r--r-- 1 pi pi 21663 Jul 5 2023 portaudio.c
-rw-r--r-- 1 pi pi 4516 Jul 5 2023 property.c
-rw-r--r-- 1 pi pi 1286 Jul 5 2023 property.h
-rw-r--r-- 1 pi pi 3252 Feb 3 07:20 property.o
-rw-r--r-- 1 pi pi 5789 Jul 5 2023 protocols.c
-rw-r--r-- 1 pi pi 1120 Jul 5 2023 protocols.h
-rw-r--r-- 1 pi pi 4988 Feb 3 07:20 protocols.o
-rw-r--r-- 1 pi pi 115 Jul 5 2023 protocols.props
-rw-r--r-- 1 pi pi 19045 Jul 5 2023 ps_menu.c
-rw-r--r-- 1 pi pi 751 Jul 5 2023 ps_menu.h
-rw-r--r-- 1 pi pi 14224 Feb 3 07:20 ps_menu.o
-rw-r--r-- 1 pi pi 12641 Jul 5 2023 pulseaudio.c
-rw-r--r-- 1 pi pi 8072 Feb 3 07:21 pulseaudio.o
-rw-r--r-- 1 pi pi 86962 Dec 1 14:37 radio.c
-rw-r--r-- 1 pi pi 8170 Dec 1 14:37 radio.h
-rw-r--r-- 1 pi pi 31019 Dec 1 14:37 radio_menu.c
-rw-r--r-- 1 pi pi 902 Jul 5 2023 radio_menu.h
-rw-r--r-- 1 pi pi 19872 Feb 3 07:20 radio_menu.o
-rw-r--r-- 1 pi pi 51416 Feb 3 07:20 radio.o
-rw-r--r-- 1 pi pi 1141 Jul 5 2023 README.MacApp
-rw-r--r-- 1 pi pi 2100 Jul 5 2023 README.MacOS
-rw-r--r-- 1 pi pi 812 Jul 5 2023 README.md
-rw-r--r-- 1 pi pi 405 Jul 5 2023 README_STYLE.md
-rw-r--r-- 1 pi pi 54447 Dec 1 14:37 receiver.c
-rw-r--r-- 1 pi pi 7762 Jul 5 2023 receiver.h
-rw-r--r-- 1 pi pi 30844 Feb 3 07:20 receiver.o
drwxr-xr-x 4 pi pi 4096 Jul 5 2023 release
-rw-r--r-- 1 pi pi 136688 Dec 1 14:37 rigctl.c
-rw-r--r-- 1 pi pi 920 Jul 5 2023 rigctl.h
-rw-r--r-- 1 pi pi 8515 Jul 5 2023 rigctl_menu.c
-rw-r--r-- 1 pi pi 866 Jul 5 2023 rigctl_menu.h
-rw-r--r-- 1 pi pi 8068 Feb 3 07:20 rigctl_menu.o
-rw-r--r-- 1 pi pi 59552 Feb 3 07:20 rigctl.o
-rw-r--r-- 1 pi pi 14738 Dec 1 14:37 rx_menu.c
-rw-r--r-- 1 pi pi 801 Jul 5 2023 rx_menu.h
-rw-r--r-- 1 pi pi 11448 Feb 3 07:20 rx_menu.o
-rw-r--r-- 1 pi pi 19713 Jul 5 2023 rx_panadapter.c
-rw-r--r-- 1 pi pi 917 Jul 5 2023 rx_panadapter.h
-rw-r--r-- 1 pi pi 11772 Feb 3 07:21 rx_panadapter.o
-rw-r--r-- 1 pi pi 3444 Jul 5 2023 server_menu.c
-rw-r--r-- 1 pi pi 805 Jul 5 2023 server_menu.h
-rw-r--r-- 1 pi pi 7871 Jul 5 2023 sintab.c
-rw-r--r-- 1 pi pi 78 Jul 5 2023 sintab.h
-rw-r--r-- 1 pi pi 1832 Feb 3 07:21 sintab.o
-rw-r--r-- 1 pi pi 40040 Jul 5 2023 sliders.c
-rw-r--r-- 1 pi pi 1983 Jul 5 2023 sliders.h
-rw-r--r-- 1 pi pi 28900 Feb 3 07:21 sliders.o
-rw-r--r-- 1 pi pi 11569 Jul 5 2023 soapy_discovery.c
-rw-r--r-- 1 pi pi 852 Jul 5 2023 soapy_discovery.h
-rw-r--r-- 1 pi pi 18555 Jul 5 2023 soapy_protocol.c
-rw-r--r-- 1 pi pi 2242 Jul 5 2023 soapy_protocol.h
-rw-r--r-- 1 pi pi 13277 Jul 5 2023 stemlab_discovery.c
-rw-r--r-- 1 pi pi 945 Jul 5 2023 stemlab_discovery.h
-rw-r--r-- 1 pi pi 4197 Jul 5 2023 store.c
-rw-r--r-- 1 pi pi 1243 Jul 5 2023 store.h
-rw-r--r-- 1 pi pi 3431 Jul 5 2023 store_menu.c
-rw-r--r-- 1 pi pi 822 Jul 5 2023 store_menu.h
-rw-r--r-- 1 pi pi 3968 Feb 3 07:21 store_menu.o
-rw-r--r-- 1 pi pi 3412 Feb 3 07:21 store.o
drwxr-xr-x 2 pi pi 4096 Jul 5 2023 STUFF
-rw-r--r-- 1 pi pi 11716 Jul 5 2023 switch_menu.c
-rw-r--r-- 1 pi pi 896 Jul 5 2023 switch_menu.h
-rw-r--r-- 1 pi pi 7788 Feb 3 07:21 switch_menu.o
-rw-r--r-- 1 pi pi 7351 Jul 5 2023 toolbar.c
-rw-r--r-- 1 pi pi 1938 Jul 5 2023 toolbar.h
-rw-r--r-- 1 pi pi 3736 Jul 5 2023 toolbar_menu.c
-rw-r--r-- 1 pi pi 38 Jul 5 2023 toolbar_menu.h
-rw-r--r-- 1 pi pi 3808 Feb 3 07:21 toolbar_menu.o
-rw-r--r-- 1 pi pi 5772 Feb 3 07:21 toolbar.o
-rw-r--r-- 1 pi pi 56775 Dec 1 14:37 transmitter.c
-rw-r--r-- 1 pi pi 3769 Jul 5 2023 transmitter.h
-rw-r--r-- 1 pi pi 28444 Feb 3 07:21 transmitter.o
-rw-r--r-- 1 pi pi 19237 Dec 1 14:37 tx_menu.c
-rw-r--r-- 1 pi pi 787 Jul 5 2023 tx_menu.h
-rw-r--r-- 1 pi pi 15996 Feb 3 07:21 tx_menu.o
-rw-r--r-- 1 pi pi 15373 Dec 1 14:37 tx_panadapter.c
-rw-r--r-- 1 pi pi 923 Jul 5 2023 tx_panadapter.h
-rw-r--r-- 1 pi pi 10096 Feb 3 07:21 tx_panadapter.o
-rw-r--r-- 1 pi pi 974 Jul 5 2023 version.c
-rw-r--r-- 1 pi pi 886 Jul 5 2023 version.h
-rw-r--r-- 1 pi pi 928 Feb 3 07:21 version.o
-rw-r--r-- 1 pi pi 52343 Dec 1 14:37 vfo.c
-rw-r--r-- 1 pi pi 3297 Jul 5 2023 vfo.h
-rw-r--r-- 1 pi pi 10207 Dec 1 14:37 vfo_menu.c
-rw-r--r-- 1 pi pi 810 Jul 5 2023 vfo_menu.h
-rw-r--r-- 1 pi pi 10012 Feb 3 07:21 vfo_menu.o
-rw-r--r-- 1 pi pi 30416 Feb 3 07:21 vfo.o
-rw-r--r-- 1 pi pi 2591 Jul 5 2023 vox.c
-rw-r--r-- 1 pi pi 866 Jul 5 2023 vox.h
-rw-r--r-- 1 pi pi 6319 Jul 5 2023 vox_menu.c
-rw-r--r-- 1 pi pi 871 Jul 5 2023 vox_menu.h
-rw-r--r-- 1 pi pi 7428 Feb 3 07:21 vox_menu.o
-rw-r--r-- 1 pi pi 1864 Feb 3 07:21 vox.o
-rw-r--r-- 1 pi pi 12357 Jul 5 2023 waterfall.c
-rw-r--r-- 1 pi pi 919 Jul 5 2023 waterfall.h
-rw-r--r-- 1 pi pi 5328 Feb 3 07:21 waterfall.o
-rw-r--r-- 1 pi pi 29596 Jul 5 2023 wdspWisdom00
-rw-r--r-- 1 pi pi 7866 Jul 5 2023 xvtr_menu.c
-rw-r--r-- 1 pi pi 796 Jul 5 2023 xvtr_menu.h
-rw-r--r-- 1 pi pi 7212 Feb 3 07:21 xvtr_menu.o
-rw-r--r-- 1 pi pi 10346 Jul 5 2023 zoompan.c
-rw-r--r-- 1 pi pi 1079 Jul 5 2023 zoompan.h
-rw-r--r-- 1 pi pi 9480 Feb 3 07:21 zoompan.o
laurencebarker
Postby laurencebarker » Mon Feb 03, 2025 12:31 pm
I have modified the G2 update script, incorporating KD4YAL's improvements - thank you. It also checks for libraries that need to be installed.
cd ~/github/Saturn/scripts
./update-G2.sh
Laurence Barker G8NJJ
kd4yal
Postby kd4yal » Fri Feb 07, 2025 5:32 pm
Here is a second revision of my G2 update script, The Bash script is designed to streamline the update and build processes for the "G2" project by providing a menu-driven interface. Key features include:
Menu-Driven Interface: Utilizes whiptail to present users with a text-based menu, allowing selection of various update and build tasks.
Modular Functions: Defines specific functions for tasks such as updating system libraries, pulling the latest code from the Git repository, building applications, installing device rules, copying desktop icons, verifying FPGA BIT files, and building the pihpsdr application.
Error Handling: Incorporates a check_status function to provide feedback on the success or failure of each operation, enhancing debugging and user awareness.
Git Integration: Includes functionality to update the Git repository and retrieve the current commit hash, ensuring the latest code is in use.
Build Automation: Automates the build processes for both p2app and desktop applications, reducing manual intervention.
System Configuration: Offers options to install udev rules and copy desktop icons, facilitating system setup and configuration.
Comprehensive Updates: Provides an option to perform all tasks sequentially, enabling a complete system update with minimal user input.
This script enhances efficiency by automating routine tasks and offering a user-friendly interface for managing the project's update and build processes. Could use a little more work but seems to be a good framework.
Enjoy 73 Jerry KD4YAL
update-G2-menu.sh.txt
(6.97 KiB) Downloaded 338 times
KC2QMA
Postby KC2QMA » Mon Feb 10, 2025 12:37 pm
Now were finally getting to a "Simplified Update Procedure"
Thank You Jerry KD4YAL for your work on the install script !
When you buy a new car at the dealer, they don't also expect the customer to also be a auto mechanic ;)
kd4yal
Postby kd4yal » Tue Feb 11, 2025 8:19 pm
Hi John (KC2QMA),
Keep in mind other manufacturers aren't opening their software to the world.
I don't mind putting in a little time to help improve the product. This is the
idea behind open-source software.
The end result, you will have a hot rod instead of a factory car like everyone else.
Jerry, KD4YAL
K0PJ/9
Re: G2 P2APP Updated files and simplified update procedure
Postby K0PJ/9 » Tue Apr 01, 2025 12:58 am
Has anyone successfully updated P2APP a G2 Ultra with an 8 inch display?
My terminal comes up: pi@raspberrypi:~ $
Attempting to change to the root directory as a YouTube video suggests, cd ~ prior to the github update script does not work.
Greg
Trucker
Postby Trucker » Tue Apr 01, 2025 1:20 am
That is the correct directory to run the update scripts from. If you are like me, you probably have a typing error causing your problems.
Trucker
Postby Trucker » Mon Apr 07, 2025 8:46 pm
kd4yal wrote:Here is a second revision of my G2 update script, The Bash script is designed to streamline the update and build processes for the "G2" project by providing a menu-driven interface. Key features include:
Jerry,
Thank you for sharing this script. Being a Linux newbie I am not sure how to go about setting it up correctly. If you could offer a few hints on how to setup and use your Bash script I for one, would be grateful.
I am sure it isn't that difficult, but I hesitate trying just anything and messing up a working system. ( I have read some things on using a Bash script online, but I am not certain if the procedure is correct)
Any guidance you can offer would be appreciated.
