G2 Line In
Posted: Wed Aug 23, 2023 12:57 am
by W7GES
Would someone else that has a G2 with knobs check if Thetis transmits audio via the Line in rear panel jack?
I'm transitioning from an Anan 7000 MKII black panel and I don't get SSB / FT8 audio via the line in jack using Thetis.
I can transmit audio via the front panel microphone jack and the XLR/TRS jack (if I start P2APP with the xlr option).
If I select the microphone and send audio to the line in jack via N1MM I do get audio at a low level. If I send microphone audio to the line in jack I don't get audio at all. The microphone and N1MM audio source for the G2 line in jack is a Presonus Studio 192 Mobile soundcard that I have used successfully with the 7000 MKII since I purchased it.
I've tried both the tip and the ring for the input audio.
George / W7GES
Re: G2 Line In
Posted: Wed Aug 23, 2023 3:10 am
by W7GES
This will probably turn out to be a mislabeled cable.
After I shut everything down tonight I pulled the rig out again and noticed a had a PTT in cable and a Line In cable but no PTT out cable (I marked the cables with a label maker when I took the 7000 MKII off the desk).
I looked behind the desk and the cable marked Line In ran towards the amplifier.
Tomorrow I will look to see if the Line In cable was accidentally pulled out of the 7000 MKII and not labeled.
Re: G2 Line In
Posted: Wed Aug 23, 2023 11:14 am
by KC2QMA
I too have not been able to get the Line-in or Balanced XLR inputs to work on my G2 no screen model running Thetis 2.10.0?
Re: G2 Line In
Posted: Wed Aug 23, 2023 3:47 pm
by KI4P
KC2QMA wrote:I too have not been able to get the Line-in or Balanced XLR inputs to work on my G2 no screen model running Thetis 2.10.0?
Have you used the PI program to change inputs?
Re: G2 Line In
Posted: Wed Aug 23, 2023 4:23 pm
by laurencebarker
The newest release of piHPSDR can select the XLR input from a setup form control. Soon Thetis will be able to do the same.
I've found why line in isn't working (the code is taking right line in, and it should be left). That will be fixed soon and I'm making audiotest able to show line in signal level too.
Re: G2 Line In
Posted: Wed Aug 23, 2023 8:05 pm
by echo_india
laurencebarker wrote:The newest release of piHPSDR can select the XLR input from a setup form control. Soon Thetis will be able to do the same.
Thanks Laurence, this is good news.
Re: G2 Line In
Posted: Wed Aug 23, 2023 8:21 pm
by echo_india
The p2app starts by default without arguments. You can auto enable the xlr mic input as I have done by following what is documented in the Saturn manual. However, I found the following the best option to edit in the rc.local file
Code: Select all
pi@raspberrypi:~ $ sudo geany /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other # value on error.
# In order to enable or disable this script just change the execution # bits.
# By default this script does nothing. # Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
sleep 10
/home/pi/github/Saturn/sw_projects/P2_app/p2app -m xlr &
exit 0
Re: G2 Line In
Posted: Wed Aug 23, 2023 10:20 pm
by KC2QMA
Re: G2 Line In
Posted: Wed Aug 23, 2023 10:45 pm
by W7GES
Is this line in issue only in pihspsdr or is it affecting Thetis as well?
Either way I will be able to test if my cable is supplying audio via the audiotest application.
I see there were changes made today to the repository for audiotest. Can I just git pull and make to get the updated version or are there additional changes that will need to be made in the repository first?
George / W7GES
