G2 Pure Signal not working with Thetis.
Posted: Fri Oct 04, 2024 8:48 pm
by echo_india
Pure signal is not working with Thetis but is working with Pihpsdr.
Code: Select all
FPGA BIT file data code = 30092023
 Product: Saturn; Version = 2
 FPGA Firmware loaded: Saturn, full function; FW Version = 10
All clocks present
p2app client app software Version:27 Build Date:5 Sep 2024 20:48:26
Die Temp = 48.9C
calculating new CW ramp, length = 5000 us
spinning up Check For Exit thread
spinning up DDC specific thread with port 1025
spinning up DUC specific thread with port 1026
spinning up high priority incoming thread with port 1027
spinning up speaker audio thread with port 1028
spinning up DUC I/Q thread with port 1029
spinning up outgoing mic thread with port 1026
loading new FIFO sizes for updated firmware <= 12
spinning up outgoing high priority with port 1025
spinning up outgoing I/Q thread with port 1035
I didn't do any firmware updates recently and only updated Thetis to current release candidate 3. I have rolled back to earlier versions of Thetis to test, and same result.
G2 ps not working.png (802.14 KiB) Viewed 3043 times
Seems to be working perfect with Pihpdsr with external coupler and also working without coupler.
correcting during normal audio input.png (214.59 KiB) Viewed 3043 times
I have completely removed Thetis from PC and started from scratch which has not helped any.
Any ideas? Thanks.
Re: G2 Pure Signal not working with Thetis.
Posted: Sat Oct 05, 2024 12:52 am
Not sure whether this is relevant but your DUP button isn't activated, maybe it should be toggled On.
Posted: Sat Oct 05, 2024 10:07 am
by echo_india
Reinstalled Thetis again, and now PS is working. A bit if a mystery.
