Strange CW behaviour of the G2 - RF or relay hot-switching???
Posted: Wed Feb 26, 2025 9:13 pm
by Michael
Dear all,
I noticed a somewhat strange CW behaviour which occasionally appears but in particular when operating a contest at high speed for a longer time period. CW signal (and audio) is stumbling (dit and dahs get stuck). This happens when keying the radio via a paddle directly connected to the radio as well as when keying via a com port eg using N1MM+. After a few seconds the CW signal becomes clean again.
It sounds like RF but I assume it is rather related to a hot switching of a relay which cannot handle high speed CW for a longer time period. Has anybody experienced a similar issue? Any suggestions to solve this?
Cheers, Michael
Re: Strange CW behaviour of the G2 - RF or relay hot-switching???
Posted: Tue Apr 08, 2025 7:37 am
by Michael
no response so far.Nobodyelse experiencing same issues with CW?
Just experienced the same issue again during the OK1WC contest on 40m yesterday evening. After some 10-20min, CW is starting to 'stumble' (dits and dahs not clearly separated) like a relay which is hanging. Maybe it is only on 40m and related to RFI which I will check next week during the OK1WC contest but it could be also related to the time delay settings.
I am operating in semi-break in with 300ms, CW key-Up 30mS, KeyDown 15mS and already played around with the figures without any improvements.
Maybe it is related to the SPE 1k3 amp which I used yesterday in standbye in order to use the internal ATU and automatic antenna switch. Maybe the relays of the amp require a different relay setting in Thetis.
Is somebody using a similar setup and could you please share your delay settings. This would be helpful.
73, Michael, DF2RQ
