Hello all
I made a local contact on 80m LSB.... but on my freind display it look as I am using DSB ???
on my HPSD3.4.9 I can see at the display that I am using LSB... so what is wrong here ???
why DSB signal when I use LSB ???
it is the same if I try to use USB ...still tx DSB....
73" OZ1CT Ben
LSB mode but transmit as DSB mode ???
Re: LSB mode but transmit as DSB mode ???
Did you try power cycling the hardware and/or re-starting PowerSDR? The software and firmware can sometimes do funny things as neither is perfect.
If that doesn't work, try saving the current database (in case you want to go back), resetting the database, and see if the problem persists.
Hi Scott
I wil try today to turn of the power and see if it help...if not, I reset the database...
I will be back
73" OZ1CT Ben
I will be back
73" OZ1CT Ben
Hi Scott
I try to power off and then power on but there was no change, so I reset the database...then the radio was ok , so somthing was wrong whit the database....
73" OZ1CT Ben
73" OZ1CT Ben
