out of band transmission
f6dro
Postby f6dro » Mon Jan 13, 2025 3:05 pm
Hello ,
I am using my ANAN10 as an IF for 23cm. 28>30=1296>1298. I am not using the transverter bands but really the normal 28Mhz TX/RX output.
Soon , because of Galileo , we will have to migrate to 1298>1300.
At the moment , it is not possible with anan10/powersdr to TX from 30>32. I understand the restriction , but in case of transverter IF so not antenna transmission, could it be possible to make this possible? I don't know wether it is an anan firmware or Powersdr limitation.
Any help?
Dom/F6DRO
Re: out of band transmission
Postby w-u-2-o » Mon Jan 13, 2025 5:06 pm
Are you really still using PowerSDR? Why not Thetis?
In either case, selecting the "extended" option for the region setting should allow operation in the manner you want.
f6dro
Postby f6dro » Tue Jan 14, 2025 9:03 am
w-u-2-o wrote:Are you really still using PowerSDR? Why not Thetis?
Hi all ,
I use both , I'm going to check that , tnx
Dom
Return to “PowerSDR mRX”
