Hi Team,
Can anyone help me to set up Fldigi for running CW with my Hermes and PSDR ??
I tried, using Hamlib for Rig control in Fldigi, using one Com Port from PSDR (Com 14) . Com 24 in PSDR paired with Com-14 using Com-0-Com.
When I press Tune or T/R in Fldidgi, I get CW side tone from speaker, Radio keys to Tx mode. But Power S meter shows 0 watts and finally no power out from Radio.
In Hamlib used Radio TS2000 and Com 16 as Device. Com16 paired with com26.
In PSDR DSP/CW : Primary - Radio ; Secondary - COM14 ; PTT- None ; Key line - None.
Attached a screen shot for reference.
FlDigi Configuration with PSDR
- Hamlib3.JPG (862.29 KiB) Viewed 8072 times
- Hamlib1.JPG (1.06 MiB) Viewed 8076 times
- Hamlib2.JPG (116.41 KiB) Viewed 8078 times
Re: FlDigi Configuration with PSDR
Hi All,
I notice that if I select DIGL/U in SDR screen, I get power out.
Is that the correct way ??
If I select CWL/U, power out is zero.
73s,
Prem
73s,
Prem
Look in Setup/General/Audio
Under the Virtual Audio Cable Setup you'll see "Auto Enable".
Turn it off.
de Mike W9MDB
Turn it off.
de Mike W9MDB
A65BK wrote:Hi All,
73s,
Prem
DIGU (or DIGL) is the correct, and ONLY way with Fldigi unless you build an AFSK external keyer. The reason for this is because Fldigi only implements AFSK CW, i.e. CW using audio tones. Therefore it cannot be run semi or full break-in UNLESS you implement their so-called QSK interface. See here and here (always best to read the manual
If you want to send and receive machine CW, there are much better choices, including CwGet, CW Decoder and MRP40.
Dear Mike, Scott
Auto option already unchecked here !
In DIG mode, the CW decoding is not happening well. S I need to try some other option.
Since my CW capability is very litle, I need to have software support . hi
73s
Prem
73s
Prem
As I wrote, there are much better choices...
CW Skimmer is the best for reception, by the way. Absolutely phenomenal how much better it is than all of the other choices. No transmit facilities, though, only receive in CW Skimmer.
