Dither: what does it do, and should I use it?
Postby w-u-2-o » Sat Feb 24, 2018 1:07 pm
Bottom line up front, and from the Analog Devices application note referenced below:
"The internal transparent dither circuit dramatically improves the ADC’s SFDR response well below 100dBc for low level input signals, allowing the ADC to maintain its high dynamic range specification with only a small degradation to the noise floor."
We've all seen those check boxes in Setup > General > HPSDR: "Dither" and "Random". If you are wondering what they are for, look no further than the data sheet for the ADC used in all of the ANAN series radios:
http://cds.linear.com/docs/en/datasheet/2208fc.pdf
Those check boxes directly control the Dither and Random control lines on the ADC.
Everything you need to know about what these control lines do is in the datasheet. However, the datasheet is lengthy and perhaps difficult for some to read and understand. The much more important of two controls is the Dither control. Therefore you may want to read this application note first as it is quite a bit shorter and to more to the point:
http://www.analog.com/media/en/reference-design-documentation/design-notes/DSOL44.pdf
If you are looking for the math, this link is an excellent reference:
http://www.analog.com/en/analog-dialogue/articles/adc-input-noise.html
Adam Farson, VA7OJ/AB4OJ, who does such a fantastic job measuring radio performance, shows exactly how well Dither and Random work in his measurements of an ANAN-8000DLE:
As you can see, there is substantial improvement at lower signal levels, and little improvement at higher signal levels.
You'll note that Adam put a couple of reference lines on the graph that represent ITU-R P.372-13 radio noise levels at the 20M measurement frequency he used. It can be clearly seen that there is little difference at signal levels higher than the ITU radio noise levels Adam referenced regardless of how the Dither and Random settings are selected.
Personally I always run with both Dither and Random turned on. There is little penalty in the noise floor, sometimes none depending on conditions, and the resulting increase in SFDR and IP3 certainly can't hurt when you are faced with a great many S9-plus-a-lot signals on the band. In other words, it is better to have it and not need it, then need it and not have it.
Also, consider the ITU radio noise level recommendation data:
If your conditions are good and/or you are operating on higher frequency bands, there may be ample opportunity for both Dither and Random to contribute to better radio performance. Indeed, I live in a rural to quiet rural environment, depending on the appliances in my house ;) . This morning on 80M I saw -122dBm in the 500Hz reference bandwidth used by Adam in his measurements (metering on Sig Avg, same as Adam and in accordance with ITU-R P.372-13). Doing better than the ITU recommendation is not difficult since they are based on lossless monopole antennas, which will typically be noisier than horizontal antennas or antennas with directivity (gain). Thus I regularly see conditions far better than those shown on Adam's graph.
At any rate, you can decide for yourself if "it is better to have it and not need it or need it and not have it." Experiment!
Finally, it is worth noting that turning on the "IP+" feature on the Icom IC-7300 is equivalent to the Dither check box in PowerSDR. I'm not sure if there is a similar control on Flex radios.
NC3Z
Re: Dither: what does it do, and should I use it?
Postby NC3Z » Sat Feb 24, 2018 2:25 pm
The beauty of the Anan's is that there is little to no penalty in the noise floor when switching on and off, on a antenna or terminated input (see Sherwood's tests also) . My 7300 had (since sold) a very noticeable rise in the noise floor, both audibly and visually. From looking at Sherwood's tests the Icom 7610 and 8600 pay a big penalty.
My 200D shows nothing between the two, and luckily I have a very, very low noise environment.
Postby w-u-2-o » Sun Feb 25, 2018 7:08 pm
See update with more data in the first post.
Return to “PowerSDR mRX”
