Postby w5rcq » Sun Apr 01, 2018 5:55 am
Hi Scott, just an update on my problem installing v8 and v9. I tried several more things including running everything as administrator without success. I had about given up but I thought that my problem was connected to video somehow as the program install never even started before the fatal error was reported. I went to the Settings menu in Windows 10 and under size and layout you can adjust the size of text and apps and other items in steps of 100%, 125%, 150%, and 175%. I had set mine to 175% for a larger text size and Icons. I reset to 100% and everything now works. It is not a big deal but I believe it is a bug as all other version up through v7 worked just fine with the 175% setting. Thanks for your suggestions and the huge amount of time and effort you put into supporting us dummies. 73 Jerry W5RCQ
