Dual Receiver on Single Antenna with Splitter
Posted: Wed Jul 05, 2017 3:56 pm
With the Apache Labs 100D, you could use a splitter such as the Anzac THV-50 connected as follows:
Terminal B: Common: to Bypass
Terminal C: Split 1: to EXT1
Terminal D: Split 2: to RX2
In the Setup / General / Ant/Filters / Antenna, enable the EXT1 checkbox.
The 8000 DLE does not appear to have BYPASS or EXT terminals on the rear panel,
nor does it have CheckBoxes in the Setup / General / Ant/Filters / Antenna to enable the EXT1 or EXT2...
The XVTR issue is dealt with elsewhere...
QUESTION...
IS there a way in the 8000 DLE to use RX1 on ADC1, RX2 on ADC2, receive on ONE antenna using a splitter or other arrangement?
I use it for monitoring dual channels on USAF MARS...
but might want to monitor 10 meters while working 160 meters using a 160m dipole.
W1TR@ARRL.net
QUESTION...
W1TR@ARRL.net
