Hi Gary,
I never tried directly editing the RX frequency in the chart as you have described, but I brought up my Memory chart in OpenHPSDR and found that if I only edit the
RX Freq column, it behaves exactly as you stated. The entry in the chart changes, but the actual received frequency does NOT change. To manually edit it so that the actual receive frequency changes for that entry, you need to edit the
RX Freq column, and also the
TX Freq column. Then the actual transmit and receive frequency will change appropriately, and the label in the
RX Freq column will be correct for sorting purposes.
I'm not sure if that gives you what you are looking for, but it does seem to if I understand your intent correctly. I do not think this behavior is a bug, but rather it is a safeguard to prevent unintentional split operation when the
Split option in a memory row is not selected. Note that if the
Split option is selected, editing the
RX Freq column WILL change the actual RX frequency of the ANAN without changing the actual
TX Freq. I have used this feature to set up memories holding the repeater offsets to access the 10 meter FM repeaters.
As Scott said, double-clicking on any entry will move the ANAN to the frequency in that entry, or clicking on an entry and then pressing the
Select button will move the ANAN to the frequency in that entry.
