PowerSDR Object Reference error
Posted: Sun Apr 05, 2020 5:15 am
by va7qi
I decided to update Power SDR from 3.2.something to the latest 3.4.9.0. It installed OK, but when I start up I get an error:
"Object Reference not set to an instance of an Object at PowerSDR Console EventArgs e" plus a lengthy list of objects.
Windows was updated this evening and restart of Windows 10 and re-install of PowerSDR did not help. I also tried to delete the PowerSDR directory under OpenHPSDR, but I recall seeing another file a long time ago, which I could not locate today. Any suggestions what causes this error and what that other directory holding OpenSDR date may be?
Running Anan-10 and the latest PowerSDR works on another computer. I just want to have a dedicated computer for SDR even though the computer is subject to crashes when operating HF.
73 de va7qi, ....Erik.
Re: PowerSDR Object Reference error
Posted: Sun Apr 05, 2020 6:14 am
by DH1KLM
also deleted the settings folder? (Database, wisdom, etc)
Can you post a Screenshot from the error message?
Maybe this could also help.
viewtopic.php?f=9&t=3302&p=10055&hilit=Object+Reference#p10060
Posted: Sun Apr 05, 2020 12:29 pm
by W1AEX
Hi Erik,
Is it possible that the screen resolution settings are using something other than the default font size? As I recall the message you are seeing is one of many that shows up when the setting is moved from the default 100% setting. Not sure about Windows 10 but in Windows 7 this setting can be found in: Control Panel > Appearance and Pesonalization > Display.
EDIT: I see that Sigi also pointed to this in the post above. Easy enough to check and I think he is right!
Posted: Sun Apr 05, 2020 8:05 pm
by va7qi
Indeed, the resolution was the problem. It was set to 125% - trying to adjust to compensate for ageing eyesight :-)
Thanks for the suggestions, guys!
Posted: Wed Aug 03, 2022 11:41 pm
by wx7y
I my be having the same error on versions 3.4.9 and 3.4.8 but 3.4.7 loads fine.
I will check my Display settings
Here is the error I'm getting
Bret
WX7Y
PowerSDR version 3.4.9 and 3.4.8 Error.png (45.48 KiB) Viewed 14740 times
Posted: Wed Aug 03, 2022 11:57 pm
by wx7y
My Display settings was set at 113% and I set it for 100% it finially loaded, wow lots of frustration.
Getting the Computer for the new 7000DLE MK3 when it finially shows up from HRO as reading it won't work yet with version 2 firmware and Thetis.
73's
Bret
WX7Y
