G2 and piHPSDR RigCtrl startup of CAT connection
dl4zbg
Postby dl4zbg » Thu Sep 07, 2023 9:45 pm
this night I connected an USB to Serial RS232 adapter to the USB jack on the rear panel. I was not able to start serial communication (checkboxes for serial 0 or 1 could not be hit) - settings were preset to dev/ttyACM0 and ACM1.
Anyone tried this? Do I have to select settings on the pi before?
Any ideas/ thoughts would be appreciated.
Volker
DL4ZBG
dl4zbg
Re: G2 and piHPSDR RigCtrl startup of CAT connection
Postby dl4zbg » Fri Sep 08, 2023 9:53 pm
Solved.
dmesg | grep usb
showed me the device name /dev/ttyUSB0 for the RS232 converter. Enable RigCtrl, Enable the serial port with correct baudrate (38400 for me) and now piHSDR is talking to my Microham MK2R+.
Cheers
Volker
dl4zbg
Postby dl4zbg » Wed Sep 20, 2023 10:04 pm
Updated to release 9/19. After that update, CAT refused to work.
Anyone experiencing the same?
Volker
n1gp
Postby n1gp » Thu Sep 21, 2023 10:27 am
Try updating pihpsdr again. I was actually working on merging in some
changes in the serial handling code on 9/19 which turned out to have a bug,
but the current (todays) should work OK.
dl4zbg
Postby dl4zbg » Thu Sep 21, 2023 11:03 am
Thank you Rick! I really appreciate your work and your fast replies.
Postby w-u-2-o » Thu Sep 21, 2023 11:07 am
n1gp wrote:Try updating pihpsdr again. I was actually working on merging in some
Hi Rick,
It's really great you are actively working on pihpsdr. You might consider starting a topic in the piHPSDR section discussing your work so that folks know what's new, what's fixed, and when it's ready to be used or tested.
dl4zbg
Postby dl4zbg » Fri Sep 22, 2023 9:47 pm
CAT is back in operation, TNX Rick.
I fully agree with Scott. Developers of piHPSDR always update on Github and is not obvious for us "users" whether it is recommended to update from Github or not.
Volker
Return to “piHPSDR”
