UPDATED to 21hUpdate to 21h for the weekend in #1 post. Some bug fixes, overlays for bandstack entries, and dragging/highlighting of filter edges in CTUN, RMS detector, some new midi commands, advanced VAC option (just the start), network throttle tweaks... etc etc
Warren would like some feedback on the RMS detector if possible. Thanks to everyone who has contributed bug reports, code and fixes for this version.
Edit: just some download numbers for 21g version, 266 downloads of the 64bit version, 29 downloads for the 32bit
21hfix: 31/61dB step attenuator issue hopefully resolved. anan-100 was included in the 31 set
fix: RX2 was missed for the CTRL to SHIFT change made in 21g. RX2 scale is now linked to RX1 if SHIFT is held and it is dragged in the spectrum
fix: andromeda button bar [change antenna] function reworked. Will only change to antennas that have TX enabled - code by G8NJJ
fix: RX2 cat ZZBA command now moves down from 12m to 15m as expected
fix: RX2 cat band/up down commands can now move to band that has no band stack entries
add: RMS detector added to panadapter display for RX1, RX2 and TX - Warren NR0V
add: ringbuffer size, number in the buffer, and % in use now displayed in VAC monitor
add: checkbox to tweak NetworkThrottleIndex registry entry in Setup->General->H/W Select tab, in the network settings group. Note: Thetis needs to be running as Administrator to make any change to this registry entry. State is read from registry.
add: option to close band stack window when entry selected
add: band stack entries can be shown in the spectrum (rx1 only), option is in BandStack2 options section. Colour can be changed in Setting->Appearance->RX Display. They only show for the current bandstack. They can be selected with a mouse click. Doing so will not update a stack entry that you might be leaving
add: filter edges are hightlighted by mouse when you are able to drag them
add: you can now resize filter in CTUN by hovering mouse on an edge and dragging
add: new Advanced audio tab. More settings will appear here over time
add: midi TX filter low/high support (wheels) - code Sigi / DH1KLM
change: spectrum grid step is used when adjusting min/max of grid with the mouse by dragging the scales. Previously was a fixed 5dB
change: n1mm udp spectrum efficiency improvements
change: P1 time out code changed slightly
change: now no longer possible to select a tune meter mode from main console that is not in the setup->transmit Tune TX Meter list when you are actively tuning
