ramdor wrote:Whilst it is ok to delta drag, when one of the scales hits either the top or bottom, then the delta changes. It could be made into a 'spring' delta, but the amount of work vs the gain was not worth the time at the time, so I scrapped the prototype. I am sure it will be revisited at some point.
Rich, my whole point was that it's highly unlikely that both receivers would be seeing the same receive power, given the assumption that they're on different antennae. So what good is it to lock the receivers to the same level during dragging?
If either scale hits top or bottom during drag, hopefully it wouldn't be a lot of work to simply let that one go at that point, and when the drag is complete then update the delta.
Not being argumentative (I seem to be saying that a lot lately, lol), but I don't see any benefit to having both receivers locked to the same level during dragging or any other time.
I'm fine with letting this go now, I just wanted to clarify my concern regarding ever locking both receivers to the same level.
Thank you again for all you do, sir!
