Thetis v2.9.0.8 - meters and then some more
KC1LKO
Re: Thetis v2.9.0.8 - meters and then some more
Postby KC1LKO » Sat Mar 18, 2023 1:29 am
Richie and Ernst,
Thank you for all the effort you put into this. Great to see this be a collaboration. Hope it paves the way for other future collaborations :-)
Thank you for allowing others to see, learn and help test this along the way (ie. build from github...)
Thank you for using the github flow control and tooling (issues, branches, PRs, etc)
Thank you for the gracefulness by which you take comments, especially on design ideas.
Yes, many others contributed prior and we (and Apache Labs ! ) owe a lot to them, but reviving and re-energizing the interest in it would not be possible without the courage and passion demonstrated here.
Well done.
KC1LKO
Trucker
Postby Trucker » Sat Mar 18, 2023 1:37 am
Smooth update! I do have a couple of questions.
Rob, how are you getting the main Thetis window to resize so you can put the meters outside of the main display window? It seems I am probably missing something simple.
By the way, I am only using the clock, Signal Strength meter and a bar graph meter at the moment. I cpu usage hasn't changed at all! When I move the meters I do get a bit of stuttering of the display ( redrawing ) but, I figure that is because this Dell is using the onboard Intel Graphics chipset.
Lot's of fun!!
Thanks Ritchie and Earnest!!
Trucker
Postby Trucker » Sat Mar 18, 2023 1:59 am
Never mind!! Watching Ritchie's video I found the answer! Duh!!!!!!!!!!!!!!!!!!
Trucker
Postby Trucker » Sat Mar 18, 2023 2:08 am
Trying not to clutter up this thread. But, WOW, talk about a neat update! And my cpu usage hasn't went up at all!! Fantastic work.
vk1hx
Postby vk1hx » Sat Mar 18, 2023 11:29 am
installed the latest version.
Just one question, is it a bug or something I'm not doing correctly. I like to set my DSP Filter Sizes and Filter Types from 4096 and Low Latency to 2048 and Linear Phase. When I change them and restart Thetis, they revert back to 4096 and Low Latency.
The reason I use the Linear Phase is because I do not like the Metalica sound on RX audio.
Cheers
73, Phil - VK1HX
W2PA
Postby W2PA » Sat Mar 18, 2023 11:56 am
You need to save the new settings as part of your active transmit profile, Phil. Otherwise when you restart the profile you had before is re-loaded.
Chris, W2PA
vk1hx
Postby vk1hx » Sat Mar 18, 2023 12:01 pm
W2PA wrote:You need to save the new settings as part of your active transmit profile, Phil. Otherwise when you restart the profile you had before is re-loaded.
Awesome, thanks Chris for the tip. That worked.
Cheers
73, Phil - VK1HX
Kj6gea
Postby Kj6gea » Sat Mar 18, 2023 2:44 pm
:D WOW,I just started playing with this,thank you Ritchie and Ernst I love it.
w9mdb
Postby w9mdb » Sat Mar 18, 2023 3:37 pm
Here's version that installs correctly now -- I'll note that the Thetis installer in the code seems to want to install the x86 version by default. I had to make a link in the directory to point the x86 directory to x64 so the installer could find the correct 64-bit files.
This version has a stack trace in to hopefully help figure out the seg fault problem with the resizing.
https://www.dropbox.com/s/p0kwwafa59q2f ... 4.msi?dl=0
W2PA
Postby W2PA » Sat Mar 18, 2023 5:04 pm
Hi everyone. Here's another example of meter containers inside the Thetis console, including edge meters, analog multimeter, VFOs, clocks, and a magic eye with an escutcheon from the floor model Silvertone model 4586 from 1936, courtesy W1JA (http://www.radiophile.com) and included in Ernst's collection. It's doubly retro in a 21st century rig!
I deliberately positioned the new meter containers to hide the old meter and VFO displays. I also use an undocked cross-needle meter outside the main Thetis window, so 8 containers in all. I haven't ventured forward into RX2 yet.
On the display the is the 20m CW band this afternoon.
Congrats Richie. And Ernst- tnx for the FB meter scales, OM.
W2PA Thetis meters.png (1.73 MiB) Viewed 21995 times
Chris, W2PA
Trucker
Postby Trucker » Sat Mar 18, 2023 5:14 pm
Neat idea! Maybe at some point the new meters could be selectable for each position instead of using a container and positioning them on top of the default meters and vfo's.
Postby w-u-2-o » Sat Mar 18, 2023 6:06 pm
W2PA wrote:Hi everyone. Here's another example of meter containers inside the Thetis console...
Nice layout, Chris! Very nice! If I can ever get this to run here I'm likely to copy you ;)
BREAK
I did download your build, Mike, and will be trying that sometime very soon, thanks!
Trucker
Postby Trucker » Sat Mar 18, 2023 6:08 pm
Had to try it. My monitor is only 27". But, certainly makes a interesting difference.
SA3ATF
Postby SA3ATF » Sat Mar 18, 2023 7:34 pm
Doing a major rebuild, so have a temporary shack with only 2 24" screens. But this is what I did on one screen anyway.
Skärmbild 2023-03-18 202411.png (890.43 KiB) Viewed 21950 times
DK1WP
Postby DK1WP » Sun Mar 19, 2023 9:13 am
Very good job by Richie and Ernst, thanks for the time and effort!
It works very well. The system load has increased from 2% to 4%.
It's very fun.
Thanks a lot!
Marcus
vk1hx
Postby vk1hx » Sun Mar 19, 2023 11:37 am
wow, those meters integrated/covering over the top of the outdated built in S-meter etc would be fantastic to have as built into the Thetis GUI and as you add meters it expands out the main GUI. At least having the option to either use a container or be integrated, replace the meters etc, depending on your screen size.
Maybe it's on the cards. Nice work. Any chance we can fix up the startup image? The best SDR Software (best is lower case) and I know the meter design was by Ernst after a lot of work, but can the callsign watermark be removed? Unless it's a licensed trademark.
73, Phil - VK1HX
N4QNT
Postby N4QNT » Sun Mar 19, 2023 11:51 am
Again big THANK YOU to Richie.. and company. Totally customizable with form and function.. Love it, I like to utilize filling the blank gaps.
Postby Tony EI7BMB » Sun Mar 19, 2023 1:26 pm
Very nice Chris, just like Scott I am likely to copy you when I get it going
W2PA wrote:Hi everyone. Here's another example of meter containers inside the Thetis console,
w9ac
Postby w9ac » Sun Mar 19, 2023 1:39 pm
Current Thetis desktop in full screen mode...
m1tzr
Postby m1tzr » Sun Mar 19, 2023 1:54 pm
Thought I would share where I have placed things.
One request would be if a container could be made pop outable by just clicking anywhere in it, so it acts more like a shortcut button.
As you will see I have the cross needle meter very small, next to the magic eye across the top.
Obviously that is far to small to use but when I do want to use it I just click the pop out which brings up a big meter.
If I could just click anywhere on the image to pop in or out instead of the top right corner that would be neat.
Thanks again all involved
Paul
ea3aqr
Postby ea3aqr » Sun Mar 19, 2023 5:26 pm
After enabling "visual aproximation of notch" in DSP/MNF I have a "color bug" on my waterfall when zooming in and out.
Watch this video:
[youtube] https://www.youtube.com/watch?v=MsZOBgDWrEQ [/youtube]
Any one else?
Postby oe3ide » Sun Mar 19, 2023 6:30 pm
ea3aqr wrote:After enabling "visual aproximation of notch" in DSP/MNF I have a "color bug" on my waterfall when zooming in and out.
Watch this video:
Any one else?
Try it with activated noise floor compensation.
73 de Ernst
ea3aqr
Postby ea3aqr » Sun Mar 19, 2023 6:47 pm
Watch this video:
Any one else?
73 de Ernst
Thanks for the tip Ernst!
Checking "noise floor compensation" solves the issue.
Unfortunately, checkig it, my waterfall shows "more noise". I'm in down town Barcelona city and I'm suffering severe QRM from unfiltered switching power supplies in my neigborghood.
eu2rq
Postby eu2rq » Mon Mar 20, 2023 7:46 am
Richie! Good afternoon! it would be amazing if you could also make arbitrary movement of the blocks of buttons and sliders with a change in their size. this would allow maximum customization of the interface individually. Thank you!
rbduck
Postby rbduck » Mon Mar 20, 2023 1:33 pm
I would say that the outcome was worth the wait. Richie.....Ernst....Great Job!! and I (and many others) thank you so much. Your hard work has resulted in everything needed, right up front, to check and calibrate audio and transceiver performance. It's almost information overload. For me anyway. :D
Thanks again for all the previous and current enhancements making this the best transceiver on the ham radio market.
Cheers!
Postby w-u-2-o » Mon Mar 20, 2023 1:58 pm
w9mdb wrote:Here's version that installs correctly now -- I'll note that the Thetis installer in the code seems to want to install the x86 version by default. I had to make a link in the directory to point the x86 directory to x64 so the installer could find the correct 64-bit files.
Sorry it took me so long to try this, Mike, the weekend was busy, but it was the first thing I did this morning.
I can repeatedly and reliably reproduce this error as follow: launch Thetis, create a multimeter container, then pop out the container or try to resize it:
If I dismiss this error and proceed to add meters to the container then Thetis will freeze and crash/quit.
I hope this helps to debug this problem for Tony and I.
Tony: have you tried Mike's build yet?
Postby Tony EI7BMB » Mon Mar 20, 2023 2:14 pm
Hi Scott , Mike kindly sent me a few trace builds over the weekend. I get the first part of the error you show above .
Postby oe3ide » Mon Mar 20, 2023 2:46 pm
Just a shot in the blue sky:
Did you both have installed Visual Studio?
If I look at the path on the stacktrace, it points to c:\projects\sharpdx, which is not a part from Win10/11.
Edit: I also have installed VS, but I always run these IDE's in virutal machines.
73 de Ernst
Postby Tony EI7BMB » Mon Mar 20, 2023 3:08 pm
Hi Ernst, I do not have visual studio which is maybe why I just get the first part of the error message Scott has.
Postby w-u-2-o » Mon Mar 20, 2023 3:09 pm
oe3ide wrote:If I look at the path on the stacktrace, it points to c:\projects\sharpdx, which is not a part from Win10/11.
While I do have VS installed, there is no such folder or path on my system. I'm guessing it's an artifact from how Mike built his version.
