Receiver Recording
JohnFT61
Receiver Recording
Postby JohnFT61 » Wed Aug 16, 2023 1:48 am
When one records the receiver, are files generated, and are they saved to a directory?
When one hits the Play button during transmit, is the last audio file played?
Re: Receiver Recording
Postby oe3ide » Wed Aug 16, 2023 7:47 am
Yes, it plays the file "SDRQuickAudio.wav" located in the Thetis data directory.
GW4NNO
Postby GW4NNO » Wed Aug 16, 2023 4:13 pm
If you want to save multiple files use the "Wave" option on the main menu bar in Thetis. Files saved with this feature are stored in the Thetis folder in your standard Windows "Music" folder.
Terry GW4NNO
JohnFT61
Postby JohnFT61 » Wed Aug 16, 2023 6:41 pm
Ernst,
Where is the Data directory located? I don't see it in the same directory where the Thetis program is stored. I know it can in in many different places in Windows 10/11...
Thank you!
Postby oe3ide » Wed Aug 16, 2023 7:13 pm
JohnFT61 wrote:Ernst,
Thank you!
Usualy c:\users\<youruser>\appdata\roaming\openHPSDR\Thetis-x64
JohnFT61
Postby JohnFT61 » Thu Aug 17, 2023 2:42 am
That's it Ernst, thank you!
John
w4bf
Postby w4bf » Tue Dec 26, 2023 2:02 pm
What am I missing? I used to be able to record and playback my own transmissions using the record and playback on console, not bringing up the WAVE function.
It still works to record and playback received signals, but on my own, only get some very low level garbling and odd pictures on waterfall. Latest Thetis and using audio in/out as shown. This was very convenient to get quick check on my audio into dummy load.
Using other means, I know my signal is good and looks fine in display when transmitting, just not getting captured correctly for playback.
Self Recording.jpg (196.02 KiB) Viewed 12020 times
Postby w-u-2-o » Tue Dec 26, 2023 2:35 pm
Try updating to the latest release, 2.10.3.5 final just to be sure that's not the problem.
LarryW
Postby LarryW » Tue Dec 26, 2023 4:46 pm
I am getting the same gibberish as W4BF is reporting. I can hear my audio in the background, but garbled.
I am running P2 with the latest u1.
7000 mkll Thetis v2.8.11 21k3
P2_v2.0b
Postby oe3ide » Tue Dec 26, 2023 5:24 pm
LarryW wrote:I am getting the same gibberish as W4BF is reporting. I can hear my audio in the background, but garbled.
Do you have this set?
w4bf
Postby w4bf » Wed Dec 27, 2023 11:16 am
That fixed it ! Thank you.
LarryW
Postby LarryW » Wed Dec 27, 2023 7:35 pm
That also fixed it for me too---Thanks Ernest!
P2_v2.0b
rdwing
Postby rdwing » Thu Dec 28, 2023 5:57 am
NO, This does not fix the issue. This records the I/Q quadrature output, NOT THE TRANSMITTED AUDIO. This is insufficient and incorrect as a representation of the TX AUDIO.
Postby ramdor » Sat Dec 30, 2023 6:59 pm
rdwing wrote:NO, This does not fix the issue. This records the I/Q quadrature output, NOT THE TRANSMITTED AUDIO. This is insufficient and incorrect as a representation of the TX AUDIO.
I made some changes and have built a work in progress build. Please try https://github.com/ramdor/Thetis/releas ... 10.3.6-dev
W4WT
Postby W4WT » Sat Dec 30, 2023 7:22 pm
I just tested Richies latest Dev work and it indeed seems to be recording MIC audio now. A good test is to do a quick recording on one band, play it back to verify it, then switch to another band to see if it still plays. It does thus it couldn't be an IQ recording.
Thanks Richie!
rdwing
Postby rdwing » Sun Dec 31, 2023 12:19 am
W4WT wrote:I just tested Richies latest Dev work and it indeed seems to be recording MIC audio now. A good test is to do a quick recording on one band, play it back to verify it, then switch to another band to see if it still plays. It does thus it couldn't be an IQ recording.
Thanks Richie!
You could actually play back the I/Q recording anywhere previously, I suspect you still can. But, mic audio recording is indeed working. Thanks so much.
Joerg
Postby Joerg » Sun Dec 31, 2023 8:56 am
When playing back an audio recording without pressing the PTT or MOX button and with the CTUN button pressed, you cannot hear the audio recording if you are not exactly in the middle of the band.
With the PTT or MOX button pressed, you can hear the audio recording because the TX FIlter is on the corresponding frequency.
Only when CTUN is switched off, the TX filter positions itself in the middle and I can hear the audio transmission without pressing the PTT button.
https://youtu.be/uaugzeJ19YY
73 Joerg, DD8JM
PS The slow regression of the baseline in the video after I let go of the play button is due to the parameter "Adjust Min to Noise Floor" being set
