TCP/Cat server
qst
TCP/Cat server
Postby qst » Wed Mar 20, 2024 6:47 pm
Hello
with 4 CAT ports occupied in Thetis with Anan G2, I created a TCP/IP server in Thetis/port 127.0.0.1:50001, Bind IP port 127.0.1:13013. I obtained this data from the video linked here. The port is needed to control the Band Master application from dxatlas.com. I used VSPE port connected to TCP client. Despite the correct connection, port 16 does not work properly. I tried to use it for the TM-2 Elad. VFO tuning and other functions do not work properly. Band Maste doesn't work at all despite port 16 being added to the Omni Rig. Does the CAT TCP/IP port have any limitations that do not work with my application? Maybe there is some other software that I can use to add a CAT port outside of Thetis to connect to G2 and allow Band Master support?
Slawomir
Re: TCP/Cat server
Postby w-u-2-o » Wed Mar 20, 2024 7:06 pm
In Thetis, the TCI server and TCP/IP CAT server are two different things.
The bind port for the TCI/IP CAT server is what you want to put into VSPE. And you need to remember to enable the "Server Running" checkbox in Thetis.
If this doesn't help you then please post screen shots of what your setup looks like in Thetis, VSPE and Omnirig.
qst
Re: TCP/Cat server
Postby qst » Wed Mar 20, 2024 7:45 pm
qst
Re: TCP/Cat server
Postby qst » Wed Mar 20, 2024 8:05 pm
Re: TCP/Cat server
Postby w-u-2-o » Wed Mar 20, 2024 10:21 pm
The problem looks to be with the VSPE configuration. You can't use a TCP client device. You have to use a combination of connector and TCP server.
https://eterlogic.com/help/vspe/DeviceC ... rPage.html
https://eterlogic.com/help/vspe/DeviceT ... rPage.html
NC3Z
Re: TCP/Cat server
Postby NC3Z » Wed Mar 20, 2024 10:31 pm
Curious on what BandMaster brings to the table?
qst
Re: TCP/Cat server
Postby qst » Thu Mar 21, 2024 10:06 am
Thank you for the information. Today I will configure this server and check it in operation. Can I find a working configuration of such a VSPE server with Thetis somewhere? This will help a lot in solving my problem.
73's
Slawomir
Re: TCP/Cat server
Postby w-u-2-o » Thu Mar 21, 2024 10:11 am
Probably if anyone had already done this they'd have posted by now. You are a test pilot!
