Thetis Memory Interface
PA0ALW-Walter
Postby PA0ALW-Walter » Mon Jul 15, 2024 6:42 am
When i try to make a recording it will fail.First when try to open the "Open Rec Folder" nothing happend.
I find out that the folder is "User\...\Music\Thetis "folder,
When i start a recording it will display in the directory "User\...\Music\Thetis " folder but when the recording is fineshed, the recording file disappear immediately from the recording directory.
So is this a bug or do i something wrong?
Using Thetis V2.10.3.6 x64 dev_4
73, Walter
PA0ALW
Re: Thetis Memory Interface
Postby oe3ide » Mon Jul 15, 2024 7:35 am
How do you record? When I record (via the Button on the console or the button "Record" in the wave-dialog) it puts the recorded file (SDRQuickAudio.wav) into the Thetis data folder (%appdata%/OpenHPSDR/Thetis-x64)
PA0ALW-Walter
Postby PA0ALW-Walter » Mon Jul 15, 2024 9:30 am
When I record (via the Button on the console or the button "Record" in the wave-dialog) it puts the recorded file (SDRQuickAudio.wav) into the Thetis data folder (%appdata%/OpenHPSDR/Thetis-x64) that's working well.
But you can also record on schedule (Weekly or Montly) via the button "Memory" left the "Setup"button,and then it's going wrong on my side.
Memory Interface 1.jpg (515.28 KiB) Viewed 2405 times
Postby ramdor » Mon Jul 15, 2024 10:20 am
Please report a bug over on ....
https://github.com/ramdor/Thetis/issues ... =%5BBUG%5D
Cheers.
