Thetis v2.10.3.4 Released
Posted: Sun Nov 19, 2023 8:23 pm
Final version of v2.10.3.4 has been released
Thanks to all that tested the 6 rounds of pre-release for this version.
Get it here : https://github.com/ramdor/Thetis/releases
!! CW Warning !!
If you use CW and you have different RX and TX antenna ports configured, there is a high potential for full RF power to be present briefly on the RX port. This may lead to damage of any sensitive equipment attached to the RX port such as active antennas and the like. This situation can occur if you utilise the CWX form, serial keying/PTT, and standard hardware keys plugged into the radio. This issue is currently under investigation and has existed in Thetis for an extended period (years and years). If you are interested in following the progress, you can read more about it on GitHub here : https://github.com/ramdor/Thetis/issues/228
**Note: You can revisit these release notes by clicking the button in the setup form within the General -> H/W Select tab.**
Please report any issues over on github here : https://github.com/ramdor/Thetis/issues/new/choose
v2.10.3.4 Change Log
[add] show on startup options for ampview and linearity/ps window. Set in the linearity/ps window
[add] can now ignore 14bit Midi messages. More devices should work. Option in Setup->Serial/Network/Midi CAT->Midi
[add] can now combine midi control id, channel and status to be used as the control ID. This should allow devices that share controlIDs for multiple buttons/sliders to work. Options in Setup->Serial/Network/Midi CAT->Midi
[add] certain skins might make it snow !
[add] option to prevent rx1+rx2 attenuator linking when using diversity. Setting in the diversity form
[fix] you can now hear rx2 audio when tx'ing on rx1 and setup->rx2->auto mute rx2 on tx is turned off
[fix] mic phase reverse now calling correct function in WDSP, and can be turned on/off
[fix] Hercules DJControl Starlight midi device is now better handled. Wheel finger press for example are ignored. If you used this device before you will need to reconfigure as the control IDs will have changed
[fix] PortAudio #850 fix included
[fix] FM should now use low/high cuts. Carlson's rules used for filter width display in FM rx and tx
[fix] Andromeda ModeSpecificForm shouldn't now clear on console resize
[fix] scope in TX should now work
[fix] spot sun/greyline track should not forget the skin background if track is turned off
[fix] ui controls on the multimeter containers should now not get stuck visible
[fix] attenuator controls should now not appear above meter containers when coming out of tx
[change] tweaks to waterfall agc to minimise screen wide pulse on T/R
[change] spectrum+waterfall low/high step sizes lowered to 5
[change] multimeter container no title bar. Now applies even if not pinned. Hold shift and move mouse in the title bar area to bring it up even if hidden
[change] removed old noise floor calc method + option from setup form
[change] removed old http server as was non operational
[change] cosmetic and layout improvements to setup by Sigi DH1KLM
!! CW Warning !!
