Thetis v2.10.3.5 final release
Posted: Fri Dec 08, 2023 5:43 pm
Thetis v2.10.3.5 final release is out here : https://github.com/ramdor/Thetis/releases
Overview video : https://youtu.be/aTvEznU2fY8?si=I9vJ1bnUVAPN0lEO
Note: since release of the final there has been a fix for the following, and will show u1/u2 in the titlebar. u2 is most up to date
-u1 - 6m lna issue
-u2 - the Spectrum Grid Min Val not being restored per band, caused by recent 'dead code' clean out
v2.10.3.5 Change Log
[add] midi device DJ2GO2 Touch MIDI is now handled uniquely, and main sliders will have values reversed
[add] mox/ptt time out timer functionality in Options2 tab
[add] amp view will restore size if set to 'show on startup'
[add] new Cat/Midi support for Quick Play/Record by Sigi DH1KLM
ZZQA 1/0 QuickPlay
ZZQB 1/0 QuickRecord
[add] new option to apply 31dB tx attenuation when output power is increased and PS-A is on
[add] dBm text colour appearance option for noise floor line
[add] option to show/hide multimeter containers
[add] can now use vsql from andromeda analogue slider window. The sql buttons are now tri state, sqloff, sql, vsql
[add] cmASIO feature for 'power users'. See included documentation in the install folder/start menu. Bryan W4WMT
[add] cmASIO icon on status bar. Green if ok and in use. Red if there is a problem.
[add] someone in red might show up when it snows from now until the 26th Dec
[add] option in VAC1 to cause VOX to use MIC instead of VAC
[add] option to stop RX1/2 waterfall on TX
[add] status bar icons for tci, cat serial, cat tcp/ip, n1mm
[add] option in options2 tab to auto power on at startup
[add] buttons [=] for RX1/RX2 waterfall and spectrum grid to copy current low/high min/max to all other bands
[fix] lin waterfall palettes should now look better
[fix] fix an issue which would prevent manually changing TX filter in setup form, it would try to 'validate' whilst typing new value
[fix] fix collapsed andromeda sql gain sliders from behaving erratically
[fix] thin notches would not clear single pixel carriers from waterfall if visual approximation was used
[fix] re-write of the usb-bcd code so that only the device in use is opened/closed as equired. Also recovers state at startup
[fix] fix issue where if diversity gain/phase locks are on changing band would overwrite the new band with the locked values. Now new band values are applied then locked if needed
[fix] menu bar has text size fixed like all other control so size/height does not change with OS text scale. Fixes cut off vfoA/B group box labels
[fix] scope time base differences between RX and TX should be resolved
[fix] Protocol 1 MAC address now correcly obtained from the discovery packet sent from the radio on port 1024. P1 MAC addy starts at byte 3, not byte 5
[fix] fixed an issue that caused the spectral area to be recentred for rx1+rx2 when shift was held to peform a ZTB for RX2
[change] wav file recording volume is normalised to ignore RX AF. Note: when muted/0vol recording is 'silent'
[change] finder will now gather info using multiple threads at a time. Some users were reporting startup time delay
[change] skinserver now attempts to select skin when downloaded and shows 'wait' mouse pointer whilst changing
[change] sql reworked to fix collapsed view analogue slider issues. Will require you to setup your sql/vsql levels again
[change] protocol tri state checkbox changed over to 3 radio buttons, one to select each protocol, and one to select auto
[change] vfosync in diversity form now mirrors state at top of main console
[change] scope display time is now in ms, and will take that long to fill the width of the view
[change] normalising PBSNR now does not adjust noise floor
[change] layout adjustments by DK1KLM
-u1 - 6m lna issue
ZZQA 1/0 QuickPlay
