Split function
Posted: Fri Jan 05, 2024 5:21 pm
by W9BHI
I noticed that the Split function does not work in the 11 meter mode. It works on all other bands.
Is this something that could be fixed in the future?
Thanks.
Re: Split function
Posted: Sat Jan 06, 2024 1:26 am
by vk1hx
W9BHI wrote:Richie,
Thanks.
Tested into a dummy load and split works fine on 11m band on my setup. Running Thetis 2.10.3.5 u2 and Thetis 2.10.3.6 dev.
Re: Split function
Posted: Sat Jan 06, 2024 1:51 am
by W9BHI
Running 2.10.3.5 U2. VFO A set to 27850 and VFO B set to 27950. Split button never turns blue when selected.
Re: Split function
Posted: Sat Jan 06, 2024 1:56 am
by W9BHI
A friend with an 8000DLE tried it and he gets the same thing, split not working on 11 meters.
Re: Split function
Posted: Sat Jan 06, 2024 4:32 am
Yeah some issues there, will add to the list and look at it when I get some time/energy.
Green when selected stops the split from working even though band is not changing. Orange also causes some problems.
edit: AND region is extended (same for all countries it seems)
- broken.png (5.9 KiB) Viewed 4004 times
Re: Split function
Posted: Sat Jan 06, 2024 6:16 am
by W9BHI
I had the Disable Split on Band Change checked. Unchecked it and split on 11 meters now works!
Thanks for the quick reply.
Don
