RX Ant Selector
Posted: Wed Feb 07, 2024 12:43 am
I connected a second antenna to Ant 2. I can switch between Rx Ant 1 and Rx Ant 2 using the Thetis selector at the bottom of the UI. I can also configure the antennas by band in Setup, Ant/Filters tab. However, UI selector only works when the VFO is in the Ham Bands. When I go out of the Ham Bands the Ant Selector in the UI has no effect. I can change the Rx antenna using the Setup, Ant/Filters screen when out of the Ham Bands by changing the Ham Band antenna closest to the Rx frequency. I use the Anan for SWL so it's an extra step to change RX Antenna when listening outside the Ham Bands. Am I missing something? I am running Thetis 2.10.3.6 dev_2 with P2 fw 2.1.18. Thanks!
